Results 1 to 10 of 14
Thread: wireless SSR?
    Dubois, PA
    200
    Default wireless SSR?
    I currently have two renards running 20 SSrez's. I'm going to use raspberry PI's to run my pixels wireless and would like to also get rid of the cat6 between the renard and the ssr. Anybody know of an wireless SSr ?
    2015 - (4) E6804's, (2) E6802's, (2) Renard 64's all loaded with blinky flashies
    Northern California
    1,062
    Default Re: wireless SSR?
    What is a wireless SSR? Do you mean something more like a small wireless controller which would fit in an SSR box?
    That is, an SSRez is basically a 4 channel Triac board which is controlled by 4 logic level signals; the timing of the logic level (sync'ed to AC) requires an external controller. Doing that level of control (4 logic level triggers for triacs) wirelessly doesn't make a lot of sense. You kinda need a uC to handle the OTA protocol, at which point why not handle the dimming/timing locally as well (ie: become a real controller).
    I recently proposed a 4 channel wireless dimming controller; it would have 4 or 6 VO2223A opto-triacs, another optocoupler for zero cross detect, an Arduino Pro Micro or ATMega328, an nRF24L01+ transceiver, and a 120 VAC->5V (or 3.3v) power supply. It would use the Komby protocol over the air, and it would handle dimming those channels. The goal was to fit into the same size box as an SSRez or similar SSR, with no ethernet cable (tho I've since realized that a somewhat more waterproof box would work, since there's no need to plug a cable in). I have NOT built this (on the stack), but I have tested the tricky parts of the coding. I chose the opto-triac because I would only be dimming small loads, like LED strings or short incans, so a small and cheap Optotriac could work; others might prefer a real external triac for more power.
    Is this (small, low channel count, low cost wireless AC dimming controller which externally looks more like an SSR box) the kind of thing you are really looking for? Nobody mentioned anything in exactly that niche, but a miniREN + wireless adapter comes fairly close. And maybe someday I'll build my concept, if somebody else doesn't first.
    9,216
    The MiniRen8/4 is small (about 3" x 3.5") and has 4 on-board triacs so it's pretty close to a wireless SSR. You can plug an XBee radio into it, one of Komby's wireless gizmos if you want to use his control system or an ESP Snap-In if you want full Wi-Fi use.
    http://digwdf.com/store/product.php?id_product=13
    Alternately, you could connect a DIGWDF ESP Thing to the DIGWDF ZCSSR and have essentially the same thing that would handle even more current.
    ESP Thing: http://digwdf.com/store/product.php?id_product=220
    ZCSSR: http://digwdf.com/store/product.php?id_product=228
    At DIGWDF we specialize in weird things.
    Dubois, PA
    200
    Jan 2010
    New Zealand
    256
    Rather than Arduino Pro/Mega, I suggest using ESP8266 (e.g. Wemos D1 mini). It has Wifi builtin, small form-factor, and plenty of GPIO pins.
    Northern California
    1,062
    Quote Originally Posted by frankv View Post
    Has anyone found a way to implement multi-channel AC dimming control with an ESP8266? That is, detect zero crossing, and and control 4 (or more) triacs with proper timing to each?
    The challenge with the ESP8266 is that it needs to share the CPU between the wireless side and the user code side, making tight timing more difficult. If someone has found a way to do this, it would make using an ESP8266 in this way very interesting!
    Thus the first DIGWDF solution uses a wireless snapin to convey serial data to the PIC on board with the Triacs (the PIC handles the timing), while in the second solution the wireless adapter has the PIC to do the timing. Neither works without the PIC. Both are cool solutions tho! But it would be really minimal if we could use just the esp8266 as you suggest.
    9,216
    It depends on whether you're looking for something that works "right now," or whether you're looking for a "project to develop." Sounds to me like more of the latter. Go for it. Make it work.
    Griswold, Connecticut
    311
    Since he already has 20 SSRez's, would another solution be to use a TINYREN8XB Board with the ESP Snap-In along with SSRez's that he already has?
    9,216
    Yes, that could work fine, too, although you'd need to provide a ZC signal to the TinyRen if it's going to work with AC lights and dimming. Of course, the DIGWDF store has a ZC kit too....
    ....we specialize in having the weird circuit boards and kits....
    UK S80 postcode
    1,439
    Hi, it should be possible to use an ESP to switch a few channels, the fun bit is doing it without interrupts and not missing the new packet or the zero cross pulse. The hard part daft as it sounds looks like it will be if no AC is connected, once it is and a zero cross pulse has been detected we know when the next one is due and can go back and loop until we see it. With no AC connected it would be stuck in the loop and the WDT (Watch Dog Timer) would kick in. I suppose not a problem if the ESP is powered indirectly from the mains.
    Now Christmas and my son’s birthday are out of the way I'll have some time to do an evaluation of this. I don't have a H11A1 on the bench so I'll have to simulate the high pulse this with another device. Can someone confirm the real world spec for this pulse please. I’ll work on 100uS until this is confirmed.
