Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 110
Thread: Startup Project - Leaping Arches
    Netherlands, Lochem
    127
    Default Re: Startup Project - Leaping Arches
    Quote Originally Posted by deonb View Post
    I don't think it needs to be - I have scuffs, dirt & sharpie marks all over my (HDPE) arches - those are visible in the daylight, but once they're lit at night the contrast to the dark night is so extreme that you can't see any flaws on them unless you're within a foot of it.
    Won't u ship me 30ft of hdpe pipe?
    Sep 2013
    Seattle, WA
    1,105
    Quote Originally Posted by Sammy2004 View Post
    I could... but I'd have to cut them into 1 meter segments.
    Or alternatively put it on a cargo ship and then you're looking at ~$1000 shipping... WHICH, if you want to buy 20 roles of it and resell, may not actually be that bad.
    2017: 33069 pixels, 24 E682's. 50 A/C with 2 LOR
    2016: 21500 pixels, 24 E682's. 6 A/C with 2 LOR
    2015: 7500 pixels, 11 E682's. 35 A/C with 3 LOR
    5,931
    China can't deliver.
    Not for a decent price that is.
    2000mm isn't a problem. But 2500mm is.
    Could I make the inside of a tube frosted/opal myself?
    Chemicals maybe?
    naptha mixed with white plasti dip will frost the inside .
  4. Thanks Sammy2004 thanked for this post
  5. #24
    Netherlands, Lochem
    127
    So no real solutions.
  6. #25
    Netherlands, Lochem
    127
  7. #26
    Netherlands, Lochem
    127
    Anyone any experience with satin tubes? Instead if opal colour? Opal has 34% translucency (opacity) and satin has 77-80%
    Manufacturer said it should disperse light correctly and dense enough to not see the ledstrip from the outside.
  8. #27
    Netherlands, Lochem
    127
    Or was it serious?
    Would it work with terpentine and white plasti dip?
  9. #28
    Netherlands, Lochem
    127
    https://www.prodip.eu/Plasti-Dip-Aer...pray-Can-White
    And add xylene thinner?
    Then just pour it into the tube?
  10. #29
    5,931
    Pixel density and distancing away from the surface to be illuminated can reduce visibility .
    Xylene and Toluene may work also but quite harmful to one's health .
    Would advise you to Check MSDS prior to using > all above .
  11. #30
    333
    I can only get small diameter.
    Really want ID to be around 1 1/2 inch.
    Just looks better imho.
    Trying to figure out different solution.
    Would be neat when I could make transparant regular pvc tube, opal.
    Your HD/Lowes doesn't carry PEX?
