Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 128
Thread: 100W RGB LED driver board for flood lights (WS2811)
    Eagan, Mn.
    4,076
    Default Re: 100W RGB LED driver board for flood lights (WS2811)
    Quote Originally Posted by Cdanna77 View Post
    So sorry for the noob question.
    Do you have a list/links to needed materials to complete this build. I ordered 2 100w versions to get my feet wet.
    You will need a power supply and a housing and wiring. It looks like several different voltage power supplies will work (maybe someone will chime in on which ones and why one would be better than the other). Housing people have used several different types and even made their own, but I'm sure we can get a link to the common one. Wiring, most use pigtails but you could use whatever you use in your show as long as the wire is heavy enough for the load. A lot of words but not much detail for you , sorry.
    3,032
    Quote Originally Posted by RobG View Post
    ... I am also considering making generic board (LED connected via wires.)
    Rob, I will cast my vote for a separate LED / control board. If the fan should fail, then the control board has a better chance of surviving. (Some of my floods will be "out of reach" once they are placed.)
    Tampa, FL
    1,340
    Power requirements for the 100w were posted in one of his threads I just can't seem to find it at the moment but it should probably be restated here what each one will require at 100%
    Chris
    Holiday Lighting, LLC
    Your Source for Genuine Mean Well Power Supplies
    https://holiday.lighting
    http://holiday.lighting/images/icons/facebook-icon.png https://facebook.com/holidaylightingllc
    http://holiday.lighting/images/icons/twitter-icon.png @holidaylightin9
    Dallas TX
    671
    Quote Originally Posted by MrSmoofy View Post
    Its in post #7
    Yes, 36V @ 3A.
    Tampa, FL
    1,340
    Quote Originally Posted by pixelpuppy View Post
    Its in post #7
    Thanks not sure why I could not find it
    Sent from my SM-G935V using Tapatalk
    Chris
    Tampa, FL
    1,340
    So the LRS-350-36's that I have are 9.7a so be interesting to see how they do with 3 flood lights will have to do some burn in testing to see how it holds up.
    Chris
    May 2016
    369
    I'm thinking that it'll be difficult to waterproof the entire light. The heat sink-LED junction could be waterproofed with some high-temp silicone, but the fan needs to be exposed to the air. I'll be interested to see what people come up with for a housing.
    Nov 2012
    Cary, NC, US
    1,229
    100W boards are here. I will do final assembly, testing, and invoicing in the next few days.
    Tucson, AZ
    668
    So Rob, I signed up for the 50w groupbuy over at the green site. Are these the boards we are running with for that group buy?
    Oct 2016
    San Mateo, CA
    137
    Same question for me...
