Thread: Is this a way to cheat on power injection?
    Dec 2015
    New Hampshire
    128
    Default Is this a way to cheat on power injection?
    Sorry for yet another Noob question
    Imagine the attached image is a single 100-pixel WS2811 5v string mounted on a window frame. (I've left a big gap between the start of the string and the end of the string for illustrative purposes.)
    Assuming I've properly fused things, is this a way to cheat on power injection? Can I simply solder my positive and negative wires from my power supply in the middle of a string so power goes in both directions and that way I'm not having voltage drop after 50 pixels?
    Will this work?
    Nov 2012
    Wenatchee, WA
    330
    Default Re: Is this a way to cheat on power injection?
    Yes
    UK S80 postcode
    1,220
    Hi, yes that will work fine. You could have equaly fed at the start (same place as the data) and at the end (just next to it).
    If you had 350 pixels you could feed at the start (feeds 0->50), at 100 (feeds 100->50 & 100->150), at 200 (feeds 200->150 & 200->250) & at 300 (feeds 300->250 & 300->350).
    You would need 3A minumum supply / fuse for the first (50 pixels) and 6A for the others (100 pixels).
