Results 1 to 10 of 13
Thread: Projector, projecting from my garage window....need talked into or out of.
    Aug 2016
    136
    Default Projector, projecting from my garage window....need talked into or out of.
    Hello. Have one of those possible good/bad ideas, looking for some guidance. Thinking of adding to my Christmas Holiday display this year with some video. Would be nice to include Halloween too.
    My garage is set up so there are windows that face the front lawn (where I'm thinking of putting a screen for video). Could put a projector in my garage and project thru the window. Couple of plus's here are the garage will keep projector weather proof and secure. If window is clean should pass light thru ok. My biggest concern is the screen outdoors. I get a lot of windy days and fear my screen will not be able to stand up to the wind (it would basically be a big sail on windy days). Was thinking of making screen out of Plexiglas and put a opaque screen/cover on it to catch the light. Maybe could put some springs and such on things to act as shock absorbers for the frame.
    Anyways, thinking about things, not sure end results would be worth my time, effort and money. Could really use some feedback on other who have had success with outdoor rear projection setups. My display if a healthy distance off the road and video just in the garage windows will not be able to be seen (from road). My screen would have to be 8' min tall to work.
    So Cal
    77
    Default Re: Projector, projecting from my garage window....need talked into or out of.
    I did it in a corner bedroom and it worked pretty well. I just used a cheap frosted shower curtain liner inside the window. I used some scrap wood to hold it in place.
  3. Thanks frankv thanked for this post
  4. #3
    Aug 2007
    MD, USA
    953
    I did just this in my garage and it worked fine. Just make sure that there is no other lights on in the garage, they will dim the image. I used the screen that came with my projector and installed it on the inside of the garage.
    ~Jason
    [URL]http://www.tooz.us[/URL]
  5. #4
    7,004
    your screen doesn't need to be a solid piece. You can use a fabric that allows wind to pass thru it. There's various scrim materials available designed for this. But you can DIY and use something like a gauze or mesh fabric. the biggest thing to keep in mind with this when you're rear projecting though Is that the projector will likely be pointing directly at the viewers. If the screen isn't solid enough, It'll be just like a flashlight in their eyes. For this reason, outdoor projection onto scrims is usually done with front projection. However, if you can manage your projection angles well, you could make it work by making sure the light spill goes into the sky or into the ground, and not straight at the viewers.
  6. Likes Xenia liked this post
  7. #5
    St. Catharines, Ontario
    62
    In this video you can see the dancing skeletons that were projected from inside the front window out to a archway that had a window curtain bought from WalMart on it. https://youtu.be/zhr0gBKhQX0 It looked great in person.
  8. #6
    Shelby Township MI
    267
    To touch on his point of the "shining flashlight" theory, you can help avoid this by using a projector with a good "keystone" adjustment. When one side, or top/bottom is larger than another because of projector angle. You place the projector as low/high as you can, and adjust the keystoning on the projector to even out the picture. This helps eliminate the direct light. Now, for wind resistance, that is always an issue, however like it was mentioned, scrim can help with that. Lot of places sell outdoor screen material, or will custom make to size.
  9. #7
    May 2016
    90
    My backyard theater screen is a 16x9 rear projection from Carl's place (carlofet.com). You WILL will have wind problems with an 8 foot screen. You'll need to tie it down with some guy wires and earth anchors. Scrims aren't very wind transparent either. Less than a solid screen, but they'll get blown around too.
    What I might do is mount a large rear projection screen inside your garage behind the garage door and put the projector at the back of the garage. Then open the garage door to expose the screen for the display, and close it after your show is done. You'll get a massive image that may suit your needs. Some of the guys doing Halloween displays do something similar to create dynamic content for their mausoleum facades, and it looks good. Unless the wind is blowing straight at the front of the house, your screen will be more protected than if it were out on the lawn.
  10. #8
    Central New York
    171
    I've been doing a similar thing for the last 3 years for halloween. I used fabric across the whole garage and the projector inside the garage. Creates larger than life effects. Has been a big hit.
  11. #9
    53
    Ive been doing video projection for ver 5 years and baiscally I run the projector thrum my garage window onto my front lawn. I bought a 6x9 screen made for outdoors and built a frame from PVC.
    Here is a vido from a few years ago showing it in use. If interested e-mail me @ ezimnow@yahoo.com for more info if you are still interested in doing this. https://www.youtube.com/watch?v=Qwi2GU6RH0Y&t=30s
  12. #10
    53
    https://www.youtube.com/watch?v=Qwi2GU6RH0Y&t=64s
    Ive used the projector from the garage window for years. If you have any questions feel free to Pm me....
