Thread: Using Lights on the Winfield Ferris Wheel
    Jul 2014
    14
    Default Using Lights on the Winfield Ferris Wheel
    Hi Everyone
    I was wondering how to use lights on the Ferris Wheel. Some people told me I can use a slip ring. Could anyone tell me how to make one that would not dangerous as the wires are in open. Any help would be appreciated.
    Dennis
    Jan 2009
    Eagan, Mn.
    3,952
    Default Re: Using Lights on the Winfield Ferris Wheel
    Check out this thread. There are a couple options.
    http://doityourselfchristmas.com/for...light=slipring
    5
    Cool Re: Using Lights on the Winfield Ferris Wheel
    I built my a couple months ago and i use 2 slip rings, one carries power + and - and the other just data. That was my prototype. I am in the process of making one out of aluminium. https://www.youtube.com/watch?v=PLb-K9o0q0E&t=338s
    Kansas City Missouri
    1,358
    These need 240 volts?
    5
    If you want to use it for a Ferris Wheel to carry people, then you must make sure they are UL certified. I used slip ring on my Ferris Wheel (7" diameter 12 Volts dc 20amp.) and carries only Stuffed animals. It is rated 240 Volt (wind turbine slip ring) http://www.ebay.com/itm/Capsule-Slip...MAAOSwKfVXF4~7
    You must do your home work to make sure it is safe for whatever it is you are going to use it.
