Results 1 to 6 of 6
Thread: Using Lights on the Winfield Ferris Wheel
    Jul 2014
    14
    Default Using Lights on the Winfield Ferris Wheel
    Hi Everyone
    I was wondering how to use lights on the Ferris Wheel. Some people told me I can use a slip ring. Could anyone tell me how to make one that would not dangerous as the wires are in open. Any help would be appreciated.
    Dennis
    Eagan, Mn.
    4,073
    Default Re: Using Lights on the Winfield Ferris Wheel
    Check out this thread. There are a couple options.
    http://doityourselfchristmas.com/for...light=slipring
    5
    Cool Re: Using Lights on the Winfield Ferris Wheel
    I built my a couple months ago and i use 2 slip rings, one carries power + and - and the other just data. That was my prototype. I am in the process of making one out of aluminium. https://www.youtube.com/watch?v=PLb-K9o0q0E&t=338s
    Kansas City Missouri
    2,180
    These need 240 volts?
    5
    If you want to use it for a Ferris Wheel to carry people, then you must make sure they are UL certified. I used slip ring on my Ferris Wheel (7" diameter 12 Volts dc 20amp.) and carries only Stuffed animals. It is rated 240 Volt (wind turbine slip ring) http://www.ebay.com/itm/Capsule-Slip...MAAOSwKfVXF4~7
    You must do your home work to make sure it is safe for whatever it is you are going to use it.
    Oct 2010
    Ludlow Ma
    295
    https://youtu.be/zEVKKwcTkbQ
    I’m using a 6 wire slip ring from a wind generator
    Family display since 1982
    Plywood cut outs and motorized
    Over 35,000 lights
    New for 2011
    48 channels of LOR (10% complete)
    Roller Coaster (planning stages)
    Patriotic Mega tree (40% complete)
    Multi-animation skating Snoopy (Planning complete)
