Results 1 to 10 of 24
Thread: Are there higher voltage pixels?
    Dec 2015
    New Hampshire
    90
    Default Are there higher voltage pixels?
    I've been searching but so far I'm empty. Are there higher voltage (24V, 48V, 120V, etc.) pixels for sale anywhere with IC chips that are supported on Falcon boards?
    Voltage drop is such a pain in the bum. I'd like to mitigate this.
    Florida
    865
    Default Re: Are there higher voltage pixels?
    Not that I'm aware of. A few people here, even some big names like plasmadrive, run 24V and have buck converters in line to drop down to 5V at injection points.
    I'd be hard pressed to believe someone would build higher than 12V native pixel. 12V is already terribly inefficient, costs more to make, is half as bright and wastes twice the power as 5V. Going higher than 12V just makes those much worse without some type of buck regulation in line.
    EDIT Corrected
    www.billporter.info
    2014 Christmas: 1 Channel; a new house and a crazy plan.
    2015 Halloween: 2500 Channels; 3 songs. Christmas: 4500 Channels; 6 songs. Custom Wifi Pixel/Renard Controllers
    2016 Halloween: 6500 Channels; 4 songs. Christmas: 11,000 Channels; 4 songs.
    Southern IL
    876
    Quote Originally Posted by madsci1016 View Post
    Not that I'm aware of. A few people here, even some big names like plasmadrive, run 48V and have buck converters in line to drop down to 5V at injection points.
    a 12v pixel is half as bright as a 5v? Even if that were true, im not sure how that is a valid point when very few run their displays at 100%.
    Florida
    865
    Quote Originally Posted by didjareally View Post
    It's true, but some people don't notice due to the difference in the way we perceive brightness as humans. They have to reduce brightness so they don't burn up with the extra power they have to dissipate from the higher voltage rail.
    And I run my mostly 5V display at 100% all night.
    www.billporter.info
    Jun 2011
    1,563
    Thank you for that.. :-)
    Actually I run 24v and use DC-DC converters at all the injection points.. 5 or 12v. I just have a butt load of the 24v 240w waterproof power supplies.. they are real handy! I never worry about Voltage drop.
    Aug 2013
    Prairieville, LA
    738
    PLasmaDrive--Do you have a specific place from which you get your buck converters? e.g. monoprice, amazon, McMaster carr, ebay, Ray Wu, etc etc....?
    Jun 2011
    1,563
    Not sure they are 1/2 as bright.. they do draw more current, 12v @ 66ma vs 5v @ 60ma. They are less efficient. .8W vs .3W.. Same LEDs and I would assume same LED current... if that is the case they should be about the same brightness.
    However, with that said, I doubt you would know the difference even if they were run at 75% vs 100% on either of them.
    Florida
    865
    Not sure they are 1/2 as bright.. they do draw more current, 12v @ 66ma vs 5v @ 60ma. They are less efficient. .8W vs .3W.. .
    If HolidaCoro's specs are to be believe its 5V @ 60mA and 12V @ 45mA. So not half but a significant difference. The hard part is convincing (non engineering) people LED's brightness comes from the current and not from the power dissipated. People see a high wattage and think brighter bulb.
    www.billporter.info
    Jun 2011
    1,563
    Quote Originally Posted by DanJ View Post
    http://www.prodctodc.com/dc-nonisolated-converter-c-1
    Jun 2011
    1,563
    So true but I think you meant higher current not "higher wattage"... no? He said the 12v was 1/2 as bright as the 5v.. which would be backward from power. Not sure why he said it that way...
    I got my power specs off of Ray's pages... for what those are worth sometimes.. :-)
    Anyway, unless I have tested them myself or have better data sources, I try to keep my comments a bit generic ("assume", "I doubt", "not sure".... things like that) because I don't want to start posting something as fact that I can't back up.. I was unable to find a luminosity spec so can't really compare brightness... hence the vagueness on my part.
