Results 11 to 20 of 28
Thread: What is your favorite length for Ach tubes?
    3,821
    Default Re: What is your favorite length for Ach tubes?
    For the past two years I have used 60/M WS2812 5v strips. I had so many issues with them this year that I will be removing almost all of them from the show. I am in the process of designing a clip for the arches to hold bullet nodes. I expect that there will be about 150 bullet nodes on the arches when I am done.
    Sep 2013
    Seattle, WA
    1,113
    5ft diameter because EMT pipes come in 5ft pre-cut segments
    The circumference of the semi-circle is about 7.8 feet - which worked out to be 142 pixels in 60/60. At more than about 150 pixels on 60/60 you need power injection not just from both sides, but also from the center, which is a pain. So 142 is just fine.
    I was going for 144 pixels originally since that can nicely divide into a whole bunch of other numbers (so effects with groups of 2/3/4/6/8/9/12/16/18 pixels are all even), but 142 ended up working better to keep it out of the water... Oh well... It was a nice plan while it lasted.
    2017: 33069 pixels, 24 E682's. 50 A/C with 2 LOR
    2016: 21500 pixels, 24 E682's. 6 A/C with 2 LOR
    2015: 7500 pixels, 11 E682's. 35 A/C with 3 LOR
    37
    +1 On it being a bad idea to use WS2812 strips. I'm also planning on moving to bullets or squares for next year.
    Sep 2013
    Seattle, WA
    1,113
    Quote Originally Posted by MrRocketman View Post
    I've used WS2813 strips this year on 4 of my arches, and it seems to be better. Not perfect though - I had one arch temporarily freeze up during a CMY test pattern run in 20 degree weather. But much better than my WS2812 strips.
    How does bullets work with HDPE arches?
    Netherlands, Lochem
    127
    I can only go 4ft6 wide. Since I can't buy hdpe where I live. Nor pex or pert tubing.
    So only acrylat opal tubes here at 6ft8.
    Which req hot-bending by myself.
    Jun 2011
    1,882
    Thanks all.. Anyone else?
    Lombard, IL
    654
    I bought 10' pre cut sections. They work out to be 6' wide and about 3' tall. They are a mashup of Johnson and Chuchla designs. I have 8 in my display, using 60/20 strips, using 56 pixels in each arch. Worked out great to run two arches back to back per power supply and input. Love mine, they were my first venture into pixels.
    Feb 2015
    Indiana
    74
    I received my 100' of hdpe from mc master Carr ordered the 2" Id 2-1/4 od hopefully they will look as nice as the 2"
    Jun 2011
    1,882
    I cut my 100' section into 8 12.5' sections. I have them spread 9' at the bottom. I used 60/20 strip and have 66 pixels per arch. At that length They do need power from both sides to avoid color shift.
    Jon, why 12.5' and 66 pixels instead of shorter and only 60 pixels? I was thinking something around 64 pixels since that is divisible by 8 and that is what most of the music would time really good to... Just a thought.
    Jun 2011
    1,882
    Quote Originally Posted by Drewfus View Post
    That is the 2"
