Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 61
Thread: Thoughts on DIY Giant Bubble Light
    Jun 2011
    1,770
    Default Re: Thoughts on DIY Giant Bubble Light
    Bump
    Dec 2015
    66
    http://www.lightuplawrence.net/Home/...-bubble-lights this is an interesting non-liquid approach I found. I think strobing pixels in the right order could simulate bubbles from far away.
    Sent from my iPad using Tapatalk Pro
    Aug 2007
    MD, USA
    955
    I,still like the water ones better.
    Short and badly typed since written from my phone...
    ~Jason
    [URL]http://www.tooz.us[/URL]
  4. Likes plasmadrive liked this post
  5. #24
    Jun 2011
    1,770
    Quote Originally Posted by toozie21 View Post
    I think I am with you.. My tubes should hopefully be here in a week or so.. I will do a video when I am done.
  6. #25
    Aug 2007
    MD, USA
    955
    Awesome, thanks. Keep us posted, I am VERY interested in this. Are you in a cold locale where you are going to need to worry about freezing issues?
    ~Jason
  7. #26
    Colorado Springs
    3,480
    Just add some alcohol, no problemo
  8. #27
    Eagan, Mn.
    4,056
    I've seen another how to on the forums for a bigger one. I was hoping someone would speak up about it. I don't remember where :-(
    It used a "clear doll cone" for the top.
  9. #28
    Jun 2016
    16
    Quote Originally Posted by Verrous View Post
    Does HC still make this kit?
  10. #29
    Jun 2011
    1,770
    OK.. I finally received my bubblers yesterday and started playing this morning.
    The plastic bowl is hella thin. You must be very careful when you cut the hole. I hot glued two pieces of Coro to the bottom then drilled all the way thru with a hole saw from the inside. I did pre-drill a pilot hole before gluing on the Coro so I had a spot to start from. Then I hot glued on the rubber foam to the bottom of the last Coro piece. The coro gives a lot of extra strength that the bowl doesn't have on it's own. The rubber type foam should help seal around the tube. I think I will seal the edges around the outside of the stack to the rim on the bottom of the bowl.
    I drilled out the rivets real easy.. cleaned up the holes and will bondo them today and paint them when the bondo dries. That should be easy.
    Now, I pulled apart the bubblers. The pump is a bit noisy so I sandwiched it in foam. That quieted it down A LOT!
    The LEDs board comes out pretty easy by removing one screw. I was going to pull that out and add pixels but I am not sure about that yet. Those LEDs appear to be point sourced with a lens for long throw up the tube. I will play with some pixels later to see how they look. Either way I am going to have to control the LEDs if my wife doesn't need them to stand alone. (these are for her after all). The controller is a COB with just a few other components for power.
    I also found out that when you turn out the lights around it, the only this that is lit of course is the tube and the rest is pretty dark. I am going to either have to front light it so you can see it all, or put pixels inside and only light the bowl. Not sure which way to go. Maybe a combination of both.
    The last things I think I will need to figure out is a better way to hold the bubbler and weigh down the bottom other than using a paint can. This setup won't work well with any wind outside. I also need to figure out a good way to hold the bowl to the bucket. maybe as simple as wire ties.. not sure yet.
    They do look pretty cool however.. Working on the details for the rest today..
  11. #30
    Aug 2007
    MD, USA
    955
    Awesome, thanks for all the info. I am really excited about the potential about this project, so keep on rolling ;)!
    ~Jason
