Results 1 to 10 of 11
Thread: mega 2560 & solid state relay
    South Carolina
    91
    Default mega 2560 & solid state relay
    looking for a little advice I used the videos here https://www.youtube.com/channel/UCWu...I2n5eCg/videos to put together my controller the problem that I'm having Is If I use the 5 volt 2 amp dc transformer on the relay boards I get nothing But if I hook the solid state relay boards to a ground pin and the 5 volt on the mega It works PERFECT.. thanks in advance
    Morrisburg, On, Canada
    2,540
    Default Re: mega 2560 & solid state relay
    When you use the 5V @2A power supply on the relay board you still need a ground wire from the Arduino board to the ground of the 5V dc transformer circuit. Voltages are "potential differences". you can't have a monopole 5V supply.
    South Carolina
    91
    so where the ground and the vcc is I need to run a ground from the Arduino to that ground ? and one more question the ground on the channel side of the relay board does it need a ground from the Arduino as well
    2,540
    Yes.
    I'm assuming that your Arduino DC power comes from the USB port. Your relay board has a separate 5V DC transformer or power adapter. The ground from the power adapter needs to go to an Arduino ground.
  5. Thanks perfection322008 thanked for this post
  6. #5
    South Carolina
    91
    Yes I'm using USB port to power the Arduino
  7. #6
    South Carolina
    91
    Attachment 35340 this is the adapter that i'm try to power the relay board with
  8. #7
    2,540
    Don't know why but I can't open your attachment.
  9. #8
    South Carolina
    91
    Thanks for taking time to try and help me I am very grateful for It. The bright side of It Is I got 11 months to try and get it figured out . jpg.jpg
  10. #9
    2,540
    There are so many success stories here that we want others to succeed as well.
    We also know that most problems can be resolved. We just need to look at it piece by piece.
  11. #10
    South Carolina
    91
    one last question could you recommend me a power adapter that I could get to try for me relay board
