Results 21 to 30 of 31
Thread: Grinch still available?
    Nov 2012
    9
    Default Re: Grinch still available?
    Hello, I took some pictures on my Renard 32 Plus board. When I plug it in the RED power led turns on and the YELLOW status led comes on for about 2-3 seconds then turns off and starts the cycle again. The GREEN led does on turn on at all. When I try and plug in a SS board nothing happens. Any suggestions?
    Nov 2012
    9
    How do I upload a picture from my computer?
    6,215
    Quote Originally Posted by Ricki Baron View Post
    google image host
    1,215
    Reply
    Go Advanced (button bottom right)
    Find the insert Image.
    303
    This sounds like normal behavior for this controller. The flashing yellow light indicates the firmware is running, the green light flashes when it's receiving data. What do you have it connected to?
    Nov 2012
    9
    I am running Vixen 2.1 with a Renard Dimmer (modified) plug in. I have a Renard USB to RS485 Dongle. I have only hooked up one of my Renard Plus SSRhc 4 Channel High Current Relay Boards to it. I get no lights going at all from the relay board when I run one of my sequences.
    1,215
    with 2.1 make sure the com port ,speed, etc are set in the computer to match what you set in 2.1.
    Nov 2012
    9
    I have checked all this already but still nothing. Thanks for the suggestion.
    303
    If you're trying to trouble-shoot the controller you might try this utility, Renard Tester. If you can't get output with it, try increasing the number of channels. Your controller might be programmed to start at a higher channel count. A photo of the board w/jumpers visible would also help. When sending data, you should at least get a flashing indicator. Dean (aka Falcon) over at the other site is great about helping with his controllers. I have a couple of RP32's and they've been solid performers.
    1,215
    Ricki,
    Where are you located? Maybe you can make a "local" contact to help out.
