Page 8 of 8 FirstFirst ... 678
Results 71 to 80 of 80
Thread: P10 Hookups
  1. #71
    Oct 2009
    613
    Default Re: P10 Hookups
    Thanks for the explanation. I will just follow the diagram and your instructions.
  2. #72
    Oct 2009
    613
    Repeat - sorry
  3. #73
    Kansas City Missouri
    1,811
    Not sure what happened here. My P10 was working. I decided to change enclosures and now something screwy has happened. When I launched Vixen I now get this mess. I didn't change anything, just enclosures. This pic should look like the pick in post #47. The text should be in red and centered. Anyone know why this happened? I've rebooted the Pi and Vixen but get the same results.
  4. #74
    1,811
    Forgot to add pic. Here is a before and after.
  5. #75
    1,811
    Scratch my problem. I figured it out. I had added more props and I used universe 18 to run them. I had the P10 originally set for universes 18-65. The panel now is using 19-66 and works like a charm. Sorry, I had a senior moment.
  6. #76
    Nov 2012
    Wenatchee, WA
    360
    Default P10 Hookups
    Your color order is probably off, either that or your channels are shifted. You can also check all your ribbon connections to make sure none came loose in the swap.
  7. #77
    Jul 2010
    Bradenton, Florida
    117
    Can anyone help me with the right way to have my panels? I have 6 panels across and 8 panels down. I see that some have the arrows facing into each other on each set of 12 and some have them facing away from each other on each set of 12.
    How should I do this.
    I am running a BBB rev C and a octoscroller
    Thanks for the help
    John (oldandslow)
  8. #78
    Folsom, CA, USA
    1,507
    Quote Originally Posted by oldandslow View Post
    Thanks for the help
    John (oldandslow)
    Is your 6 across LANDSCAPE or PORTRAIT
    Look at post 69. Good picture of cabling/layout
    http://doityourselfchristmas.com/for...131#post464131
    In Lights Therapy
  9. #79
    Jul 2010
    Bradenton, Florida
    117
    Portrait. I was thinking I could hook up two rows of six together (12 panels) and have four feeds to the ocotocontroller. But the previous poster said I can only hook 8 and after looking I see that is has 8 ports. So that means I hook up 8 and then the last 4 on the next row must start a new 8
    new 8 so I will have 6 leads of 8 if I understand this right. How would you hook it up with the orientation of the panels?
  10. #80
    Folsom, CA, USA
    1,507
    oops, you may have a panel limit problem. Appears FPP limits to 36 P10's
    Maybe someone from the Falcon team can address this.
    In Lights Therapy
