Results 1 to 10 of 13
Thread: Which MOSFET for DCSSR
    Bristol, UK
    27
    Default Which MOSFET for DCSSR
    Looking at the DCSSR on the WIKI it suggests using either a RFP14N05L or STF20NF06 MOSFET. Looking in the UK I can only find the RFP14N05L MOSFET on http://uk.rs-online.com
    When I look for similar devices there are are whole lot of parameters or characteristics to compare. Obviously working voltage and current carrying capability are obvious but what other characteristics matter when looking for an alternative MOSFET for the DCSSR. I will be controlling 12V dc at no more than 6A using some dumb RGB strips like these http://www.lightingever.co.uk/12v-le...rproof-5m.html ( 2 units per channel ).
    Suggestions / guidance will be very much appreciated, thanks.
    192 + 12 Channels, P4 1.8GHz, Grinch & Parallel12, Win XP Sp3, Vixen 2.0
    [URL]http://tyzzerslights.org.uk/[/URL]
    Southern California
    900
    Default Re: Which MOSFET for DCSSR
    I used the STP16NF06L. I see that the website you quoted carries has a listing for. Since it is rated for 16 amps and I only load it to less than 1 amp, I don't have to worry about adding heat sinks.
    Kevin
    Morrisburg, On, Canada
    2,540
    Well, ... since you can find the RFP14N05L in the UK why look for additional substitutes that requires further research? It's a 14 amp device @ 50V so it is well within your requirements.
    5,344
    You should use a heat-sink with the RFP14N05L, as it will end up dissipating somewhere around 3W if left on continuously with a 6A load (according to the graphs in the datasheet, it will typically saturate at 6A with about a 0.5V RDS).
    UK S80 postcode
    1,456
    Hi, I've not had chance to try them yet but there are some FQPF13N06L's sat on my desk to do something simalar.
    RS are doing them in the UK with free shipping in packs of 5.
    http://uk.rs-online.com/web/p/produc...FdUaGwodquIFJA
    Bristol, UK
    27
    [Kev] RS components does carry a listing for the MOSFET but I'd rather see if I can find a cheaper alternative, but I don't know which of the characteristics I need to be concerned about other than Voltage & current.
    [Lightup] Thanks for the reply, I would look for alternatives but I don't know which of the characteristics I need to be concerned about.
    [P.Short] I would like to be able to do this without a heat-sink if I can, mainly for space, happy to use a higher current rated device. Due to lack of knowledge, what does RDS relate to?
    Thanks for your replies guy's.
    Bristol, UK
    27
    Hi Barnabybear,
    Thanks for that. What characteristics of the device make it a suitable alternative?
    I don't quite understand MOSFET's other than they appear to be power transistors of a sort.
    2,540
    ptyzzer:
    The basic characteristics are voltage, current, power, gate drive and thermal design.
    It was a course in my schooling so a blurb here wouldn't do full justice, as you are getting into design details. I haven't done this for some decades.
    You need to be able to decipher data sheets of the device you are going to use. You can start the process and have reviews done here.
    A solution can take time (and money in buying various parts) as some potential solution may use several very cheap devices and wire them in parallel. But you have to evaluate all the angles to determine if it really is cheaper, or worth the bother.
    I don't have the cheapest solution for you waiting to be built.
    Generally you pick a working design already tested by members here and go with it.
    Edit:
    There is also a software way of designing by using, say LTSpiceIV.
    http://www.linear.com/designtools/software/#LTspice
    How close it comes to the real world would need to be evaluated by building a prototype and testing it.
  9. Thanks ptyzzer thanked for this post
  10. #9
    Southern California
    900
    Quote Originally Posted by ptyzzer View Post
    [Kev] ....... but I'd rather see if I can find a cheaper alternative.......
    Yeah. Not sure what your cost is, but I paid $0.25 each two years ago for 100 pieces. They are now $0.33 each for 100 pieces from Avnet, more if you buy less quantity.
    My 16 channel DC SSR boards cost less than $1.00 per channel (actual cost of board and components at the time).
    Kevin
  11. Thanks ptyzzer thanked for this post
  12. #10
    Southern California
    900
    I built 8 of those for my show this year
    Kevin
