Results 1 to 10 of 19
Thread: Olsen 595 Output Problems
    Sep 2007
    Valley Center, Ks
    442
    Default Olsen 595 Output Problems
    Another problem cropped up today. I had a bad cat5 connector so I fixed that. Now I can't get 2 of the channels on that output to work. Here is my setup:
    2 Olsen 595's running from parallel port
    Powered by a AT computer power supply
    Using Brian's SSR's
    The LED for the channels turns on but nothing out the "O" port for output 2 & 3. 1 & 4 work fine. I tested this using Dirknerkle's SSR/CAT-X tester. The LED's turn on the 595 board but not on the tester board. I swapped the 2803 & 595 one at a time from another working board and that didn't fix it. I looked for a schematic to see what actually drives the outputs. I am guessing it is the 2803 chip does that. Actually I swapped the 2803 first then I swapped the 595 with the 2803 still swapped.
    Are there any troubleshooting steps that help with this online someplace?
    Dave-1200Px-20KLts
    Long Neck, Delaware
    360
    Default Re: Olsen 595 Output Problems
    Dave, check back at you're other post, I left you a PDF file with schematic for the Grinch board, same as the 595 but without the led's.
    http://doityourselfchristmas.com/for...en-595-Problem
    Gary
    Jan 2013
    Northern Illinois
    299
    If you are using that schematic to help troubleshoot keep in mind that the Grinch board doesn't have the ULN2803 chips.
    Sep 2007
    Valley Center, Ks
    442
    I looked at the grinch schematic and realized it is different so can't really use it.
    Dave-1200Px-20KLts
    Jan 2013
    Northern Illinois
    299
    Here's a link to the thread that has the schematic in case you need it. Keep in mind there's more than one version. Not all versions had the channel LEDs on them.
    Maybe this will help you out.
    http://doityourselfchristmas.com/for...=595+schematic
    Sep 2007
    Valley Center, Ks
    442
    Haven't tried anything yet but looking at that schematic I don't understand how the LED's come on but the output doesn't according to the tester. The 2803 provides a ground right with the resistor pack pulling up to 5 volts.
    Dave-1200Px-20KLts
    Sep 2007
    Iowa
    457
    Yeah, there's not much left..
    I couldn't find a picture that shows the traces on the bottom side of the board.. but I would do a continuity check on the 4 traces that go from the LEDs to the jack.
    possibly a bad trace, pad, jack or cat 5 cable.
    -Craig
    Jan 2013
    Northern Illinois
    299
    Here's a picture of the traces for a 595 board. Maybe it will help with your trouble shooting.
    595 Traces.pdf
    Waterboro Maine
    1,020
    You are correct the 2803 drives the ssrs
    think your problem may still be in the cat5 conector but i dont know much lol
    if my old memory is working the leds onboard run off the 595"s
    Waterboro Maine
    1,020
    Nope 595 feeds 2803 then leds then rj45 so if leds work whats next lol
