FPP Login
Trying to setup my new rasberry pi to run fpp. Followed the instructions and it boots up. FPP login: I type fpp. Password: I type falcon. Then it comes up with this and stops fpp@FPP~$. Now what?
FPP Login
You are actually done at that point. You can log into the FPP on your normal computer by typing fpp into your browser.
Re: FPP Login
So I need both on my home network and I just type fpp into my browser?
Re: FPP Login
https://youtu.be/AHdaqGYXg7E
Post Thanks / Like - 0 Thanks, 1 Likes
FPP Login
Around 3:30 in the video
Re: FPP Login
Re: FPP Login
No problem, did it for the first time yesterday myself and was confused at the same point.
Re: FPP Login
I got to the same point, put in fpp & falcon ID?Password, but it doesnt show up on my wifi network, it is on a pi 0 w, not hard wired. FPP/ in a browser takes me to google search for falcon. Thoughts?
Scot
Re: FPP Login
Chicken and egg syndrome. you cant configure fpp until you attach. you cant attach until you set the wifi name and passphrase. you cant set the wifi name etc until you attach. use a wire for first config.
Re: FPP Login
Originally Posted by
samckitt
Scot
Did you use the stock FPP SD image or the one that Paul posted specifically for the Zero W? The stock image won't work on the Zero W because the Zero W needs newer a firmware and kernel than are included in the stock image.
