Results 1 to 2 of 2
Thread: Audacity and creating beat tracks
    Aug 2012
    Nova Scotia, Canada
    1,478
    Default Audacity and creating beat tracks
    Had a weird issue crop up and figured I would share.....
    Had to install Audacity on a Windows 10 PC and installed the Queen Mary plugins for creating beat tracks and polyphonic transcription etc.
    Once installed, I would load an audio file and then try to analyze to create a beat track and it would fail over and over again with ffmpeg errors.
    It was an easy fix...
    Once you open audacity, Click EFFECT and then ADD/REMOVE PLUGIN and look at state for the vamp plugins and you will see it says NEW, just click ENABLE on each QM-vamp plugin.
    Click OK and you are good to go.
    I don't believe I ever had to do this with Windows 7, but it was a loooong time since I last installed Audacity....the old mind may be starting to go.....
    Anchorage, AK
    145
    Default Re: Audacity and creating beat tracks
    I have this problem, enable them, never get the beat bar selection. Am running windows 7. Any help would be appreciated.
