Results 1 to 7 of 7
Thread: P10 Panel A - Z
    79
    Default P10 Panel A - Z
    Is there a tutorial thread on P10 panels that basically teaches you how to assemble, program and use P10 panels in matrixes? In other words, goes from step 1 thru step xxx to get some panels up and running. When do you need an octoscroller...when do you use a Beagle Bone Black...how do they connect to the Beagle Bone .....etc
    Another example would be a Step by Step in building a "Tune To" sign and working it from xlights.
    I am totally new to P10 panels, want want to learn more about them.
    David
    Greenfield ma
    362
    Default Re: P10 Panel A - Z
    Best bet is head over to falconchristmas.com. Tons of info over there.
    Lombard, IL
    550
    Agree with lightsonmontague. I built mine this year and spent a lot of time on falcomchristmas.com. I used a Raspberry Pi and one of Ron's Pi Hats to create mine. I don't know XLights but programming was the easy part. I did mine in Vixen and exported the results to FPP format. Falcon Christmas is the way to go there. PM if you have questions.
    Lombard, IL
    550
    Forgot I found this, it might help:
    http://doityourselfchristmas.com/for...P10-help-guide
    79
    Quote Originally Posted by mikeh65 View Post
    Thanks...I have been going thru that thread and have found it most useful. I went ahead and built the matrix and have started with the BBB and FPP. Hopefully, this weekend I will be able to setup a sequence in xLights and get it to play on the panels. I am having a blast learning this stuff but let me tell you....doing it at my age is taxing. <G>
    David
    Kansas City Missouri
    1,747
    I too plan on doing a matrix next year. The links above don't work.
    Palm Bay, FL
    685
    I believe Dirk has a write up here or his site in the wiki for P10.
