Results 1 to 10 of 14
Thread: DIGWDF RenStick
    Oct 2010
    NW Suburbs of Chicago
    149
    Default DIGWDF RenStick
    How do i get the wifi signal to these. I am only using wired connections and have not tried wireless at all. What do i need to connect a wifi router to my pc to send the signal to these.I am running Vixen and renard controllers, Kind of looking for a step by step.
    Tampa, FL
    1,340
    Default Re: DIGWDF RenStick
    Quote Originally Posted by mikel3332 View Post
    Is this what you have? http://digwdf.com/store/product.php?id_product=213
    Chris
    Holiday Lighting, LLC
    Your Source for Genuine Mean Well Power Supplies
    https://holiday.lighting
    http://holiday.lighting/images/icons/facebook-icon.png https://facebook.com/holidaylightingllc
    http://holiday.lighting/images/icons/twitter-icon.png @holidaylightin9
    Oct 2010
    149
    Yepper doodle,, I'm just curious if I go from the dangle to the router or if I need something in-between
    Sent from my SM-N920T using Tapatalk
    Tampa, FL
    1,340
    You'll need to program the "dangle" to be on your wifi network. If you go to the link and look at the downloads tab I believe there to be documentation there on how to do all of that.
    Chris
    Oct 2010
    149
    Lol, I meant dongle
    9,291
    RenStick has its own complete assembly and user guide, like all the DIGWDF products. It does not include information on configuring your home wireless network, but it does include some helpful information about configuring the ESP module.
    It may be helpful to review DIGWDF's ESP Snap-In assembly & user guide as it includes screen shots of the ESPixelStick firmware settings.
    Attached Files Attached Files
    http://digwdf.org/store/
    Oct 2010
    149
    Thanks dirk,, I'm good with the stick itself, actually I'm love everything from the digwdf store,,,I was wondering if some one could help me with my pc to router setup. Right now i use a usb to cat 5 dongle to go to the renards and daisy chain them, everything is wired. I am just confused how to work a wifi router in there. Do I just use the dongle to cat 5 to the router, or do I use the ethernet port to the router.
    9,291
    Thanks for the kind comments!
    If you use a USB dongle to go to the Renards, you're using a Serial connection. As such, your sequencer is using an output plugin that sends the sequence out the serial port. Sequencers can also send the same information out the network port, but it involves using an addition output plugin (often the J1Sys plugin) to send channel data to the network instead of a COM port. Then the wi-fi router typically will transmit data they receive that way. This is a very simplistic explanation because there's more than meets the eye when you deal with wireless networks, but it's essentially it.
    Oct 2010
    149
    Thank you my friend,,that helps alot
    Oct 2010
    149
    Ok, i finally had some spare time and got the esp programmed and seen on the network, but i am lost programming the pic for the stick, i had no problem programming the pics for the renards but my pickit 2 doesnt seem to recognize the 16f1825 pic
