Results 1 to 6 of 6
Thread: Com Port denied issue
    Silsbee, Tx
    1,096
    Default Com Port denied issue
    I am setting up a new show or that is trying to this season.
    The problem is in the show program. When the first sequence finishes, the show shuts down (Renard Dimmer (modified): (Router - startup) Access to the Port 6 is denied.
    If I remove all sequences except one, the show will repeat that sequence. But if I add another sequence, it shuts down every time.
    The show ran with 5 sequences before, now it will only do one. AAARRRGH! <<<Yeah, that means I'm frustrated, but I gotta keep a positive attitude some how.
    Maybe I should drop this for now and go get my MV ready for the veterans day parade.
    Colorado Springs
    3,696
    Default Re: Com Port denied issue
    I know that at one time this sort of thing was an issue and was solved (for the most part) by making sure that you had an 'OFF' command as the last command in every sequence or it would not release the Com Port for the next song.
    California
    1,156
    I solved this a while back by using a wiznet Ethernet to serial converter. I've got a couple dual port ones if you're interested in going that route.
    2015 Plans: More pixels, add more Komby radios, and weld new props!
    [URL="http://amistosolights.com"]http://amistosolights.com[/URL]
    Oct 2009
    Nelson (New Zealand)
    435
    That problem happens often if you are attempting to use multiple USB adaptors, I use only one Prolific, and one FTDI without issue, along with 5 serial ports to drive the Ren's and wireless. Add just one extra USB - RS485 adaptor and problems, it apparently is due to sloppily written driver software.
    Terry
    [B]"Tory Street Lights", Nelson, NZ[/B]
    [B]2013 - "Honourable Mention"[/B] - 2013 Local Christmas Lighting Competition
    [B]2013 :-[/B] 11 x Ren 64XC's - 650 Channels, 45,000+ lights. 7,000 or so LED's this year:-)
    [B]"Lucky Home" [/B]- 2012 Local Christmas Lighting Competition
    [B]2012 :-[/B] 11 x Ren 64XC's - 550 Channels, 40,000+ lights. 2,500 or so LED's for the first time :-)
    [B]2011:-[/B] 7 x Ren 64XC's - 384 Channels, 30,000+ lights - all incandescents! 2 x Commercial LED Panels (72x7)!
    [B]"Supreme Winner for 2010" [/B]Local Christmas Lighting Competition, 4 x Ren 64's - 256 Channels Controlled by Vixen - "Brilliant" :-)
    18,000 to 20,000 Lights - all incandescents! 2 x LedTricks Panels with "Pix C" interface's
    [B]2009:- [/B]128 Channels of "Hill 320", 4,000 Lights
    Feb 2008
    Warminster, PA
    1,707
    Make sure "Seconds of crossfade" is set to 0.
    Chris
    9,166
    If you're using Vixen 2.1 it's possible to "double-load" it, and then there's an extra instance of Vixen running in the background that causes the conflict. Close Vixen. Then check the Windows Task Manager to see if a Vixen process is still running. If so, kill it. Then start Vixen again and you should be okay.
    http://digwdf.com/store/
