Results 1 to 5 of 5
Thread: Micro Pex Arches
    New Jersey, USA
    499
    Default Micro Pex Arches
    I posted hints of this on another thread and since that was a bit rude on my part I'll start a new thread.
    These are 12V LED arches using a pair of T10 LED "bulbs" as a segment, attached to cat5 to drive the (-) and a shared heavier gauge wire to drive the (+):
    Once all the bulbs are soldered to the wires (equally spaced), I'm getting ready to pull it through the pex:
    Here is a picture of the Tee on the base that the controller box (4x4x2) will be glued to once I find the bag of adapters I bought (but seemingly lost):
    Micro Arch Test Uncased:
    Micro Arch Test Cased:
    The arches are 4' wide and 2' tall. Almost studio-apartment sized!
  2. Thanks OriginalHotrodder thanked for this post
  3. #2
    California
    13
    Default Re: Micro Pex Arches
    Nice! I'm looking at building some of these micro-arches for our small front yard.
    It looks like you just used the 1" PEX, right? What length did you use for that sized arch?
  4. #3
    New Jersey, USA
    499
    I used 3/4" Sharkbite for the arch (bulbs inside) and 1/2" PVC for the frame and legs. I debated for a long while whether to use 3/4" or 1" pex and went with the smaller diameter because then the bulbs I slipped inside would be more "straight" rather than having the room to angle themselves. I thought that might look better.
  5. #4
    Oct 2010
    NW Suburbs of Chicago
    149
    I really like the way these look and the size is perfect. i would like to make 10 for the ridge of my roof next year, do you have a link to the bulbs. There is a million different ones on *bay
  6. #5
    New Jersey, USA
    499
    Sure!
    These are the bulbs I used: http://www.ebay.com/itm/50X-Super-Wh...pYJfvt&vxp=mtr
    The bulbs have 13 5050's on them, three per side (four sides) and one on top. I put two bulbs facing away from each other as a "segment" which gave me about a 4-1/2" width for each segment visually with the diffusion quality of the pex.
    They fit reasonably well inside 3/4" pex which has a hair more than 1/2" inside diameter which was enough room for the bulbs and the wires. I used cat5 since I have miles of it sitting around and current draw isn't very much and the distances are short (4' circumference plus 1' for the tail that goes to the controller.
  7. Thanks mikel3332 thanked for this post
    Likes mikel3332 liked this post
