Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 103
Thread: P10 Matrix
  1. #51
    13
    Default Re: P10 Matrix
    Dave. Did you go with the 9025 frame profile?
  2. #52
    98
    Yup just looked and that was the one... deep enough to mount a 350 watt PS to the back and still mount flush to the wall
  3. #53
    Kansas City Missouri
    1,788
    I checked out your link and found this. Seems to be deep enough but I need more measurements. At the front there is a channel that looks like it accepts glass/plexiglass but no size is given. Also, when ordering do you give them a final size or do you order larger than you need and you cut to size? Here's a pic of what I looked at.
  4. #54
    98
    I recommend chatting with their representative and explain what panels you have and they will generate the invoice for PayPal payment
  5. #55
    1,788
    I actually think this one is stronger due to the double channel. They did tell me the channel where plexiglass goes is 3mm which is just under 1/8" (.118"). I haven't discussed price but she did ask me the panel sze.
  6. #56
    98
    Nice... my concern was depth as it will be outside and against the wall and I didn't want the power supply to be exposed. And you will be surprised how sturdy this will be once you add the steel strips
  7. #57
    1,788
    According to the frame specs it's 57.15mm. That's about 2.25". Just enough room even with Ron's Matrix adaptor attached to the Pi and Boscoyo ps mount. I could put the Pi with Ron's adaptor off the mount which will give me another .25" of clearance but it would work just as it sits. I'm using a low profile Meanwell and there's tons of clearance there. I took my measurements from the front of the Boscoyo strips assuming I'm still going to use those to mount the panels in the frame. I'm also assuming the P10's are not included in my measuring because they will overlap the frame making the Boscoyo strips even with the front (where it says 21mm minus the P10 thickness). The thing that concerns me is what to use for a back. The measurement shown on the product can't be accurate. It shows 92mm from front to back. If you add 34.85 and 57.15 it comes out to 92 but the picture shows a overhang (bottom right of pic) included in that measurement but the 57.15 doesn't include it. I'm actually considering asking for a 6" sample piece of the 2 different ones I'm looking at.
  8. #58
    1,788
    My explanation was probably lame so here's a drawing showing how I think the panels mount in the aluminum frame.Frame Pic.png
  9. #59
    98
    Hahaha... I was picking it up. But yeah you should be good. I haven't installed any plexi into the front channel but realized after I riveted the corners on, so I would use screws on the corners.
  10. #60
    1,788
    Quote Originally Posted by davedecali View Post
    Glad you figured out what I was saying. Not sure I even understood. You can drill the rivets out. My current enclosure weights a ton and 1/4" plexiglass isn't helping. $112 bucks for a 4x8 sheet. If I go with the aluminum from I scrap the glass. Ugh! But, if I can cut the weight by a fourth it's probably worth it because I'm mounting this over the garage and it's easily 9-10 feet off the ground.
