Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 103
Thread: P10 Matrix
  1. #41
    98
    Default Re: P10 Matrix
    mocked up a simple frame for support. Thinking about a piece of plexi over the front and leaving the back open. Paint it black and call it a day. If the Chinese aluminum frame is better then I will swap it over. Originally had plans for a 5x5 but changed my mind once I visualized the actual size. This is installing in a overhang out of the little weather we get in California
  2. #42
    98
    better frame mocked up with aluminum and 1/8 steel strips. Using the magnetic mounting screws is a cleaner look in my opinion and lines up much better than using the boscoyo strips.
  3. #43
    13
    Frame is looking nice. Do you have a better picture of the depth/angles the edges are using? I have to start figuring out a frame as well.
  4. #44
    98
    there is a small channel on the front side to install a 1/8" piece of plexi but I am debating if I will need it.
  5. #45
    13
    Some beautiful work! Everyone seems to use wood which I would expect to be heavy and harder to maintain over the long run. I'm surprised no one is out there making custom frames for sale.
  6. #46
    98
    I agree... had to go to China and this thing only weighs about 20 lbs tops. Need to add the power supply and cables but waiting for the distroboards. Very happy with the alignment over using the wood frame.
  7. #47
    13
    Where did you get it from China and what was the $ if you don't mind sharing? I'm going to do a 4x8" with 64 units and need to make a frame this season.
  8. #48
    98
    Trade with this supplier via Alibaba App Shenzhen Hesheng Aluminum Products Company Limited
    https://f2rq3.app.goo.gl?link=https:...3451073&amv=69
  9. #49
    98
    Default P10 Matrix
    Wasnt sure if that link would work, but it was like 13 bucks for the frame and a hundred to ship... had it in about 2 weeks... very nice to work with and I went with the slimmer style frame but they had several to choose from. They make the frames customs sized for your requirements. I thought it was flimsy at first but adding 1/8 steel supports for the magnet attach points made this solid.
  10. #50
    13
    Default P10 Matrix
    Thanks! Sent them a message on alibaba.
