Results 1 to 10 of 14
Thread: Single Channel Pumpkins
    May 2008
    Moscow, PA
    119
    Default Single Channel Pumpkins
    I was wondering if anybody had any sequences they knew about or personal ones that they would be willing to share that are single channel pumpkins singing? I have four of those inexpensive light up jack o lanterns from Walmart, and I would love to see them sing to songs like "This is Halloween."
    I'm not looking for animated faces, just again 1 channel per pumpkin.
    Any links would be greatly appreciated, otherwise I will just slowly bang one or two sequences out over the next two weeks.
    "Russ, Get a Flashlight, I blew a Fuse"
    Meanwhile..."General, the Nuclear Power plant has been activated to restore power to the city."
    Proud DIYC member who hopes to do this someday.
    Aug 2011
    Zephyrhills, FL
    129
    Default Re: Single Channel Pumpkins
    I have an 8 ch singing pumpkin set up with a few other channel/objects in there that could easily be removed or modified. I have 3 songs they sing to; This is Halloween (Manson version), Grim Grinning Ghosts and Thriller. I have them available in Vixen 2.1 version as well as Vixen 3.2 version. Let me know if you are interested and I will get them together.
    May 2008
    Moscow, PA
    119
    Quote Originally Posted by wirenut1980 View Post
    If you would be willing to share the Vixen 2.1 versions I would be very grateful!
    1,527
    Yes Please. 2.1 or 3.2
  5. Thanks miw01 thanked for this post
  6. #5
    1
    I'd be interested in this as well, if you'd be willing to share!
  7. #6
    Aug 2011
    Zephyrhills, FL
    129
    Here are the 3 songs in Vixen 2.1 format. The audio will be sent to you in a separate file through PM. Let me know if you have any questions, and hope this helps.
    Attached Files Attached Files
  8. Thanks Jerry-Rigs thanked for this post
  9. #7
    Aug 2011
    Zephyrhills, FL
    129
    I see I can't send a file through PM, so if you would like the audio files send me a PM with your email address and I will send it.
  10. #8
    Ashburn, VA
    435
    Thanks for sharing!
    Are the audio files stock" (un-customized)?
    If so, we can obtain our own copies of the audio.
  11. #9
    Houston, TX (near Katy)
    993
    I have some Vixen 2.1 Pumpkin sequences with 1 singing pumpkin and 10 carved pumpkins I will look for and post later tonight. They were converted from some LMS files that someone gave me. I also have a video of them playing. I will try to upload that tonight as well and post the link. Nothing fancy, but it worked that year.
    That's a feature not a bug.
    There's no charge for that.
  12. #10
    Aug 2011
    Zephyrhills, FL
    129
    I know for sure I had run the audio files through audacity to adjust the volume levels so that all of the songs would play at the same level. If the stock songs don't match the start point, if I can remember in 2.1 you can add blank space or delete blank space from the sequences. If this doesn't work for you just let me know and I can send the files.
  13. Thanks Jerry-Rigs thanked for this post
