Results 1 to 10 of 10
Thread: First Time Arch Builder
    Oct 2016
    49
    Default First Time Arch Builder
    Building four driveway arches this year and going with 1" EMT for the structure. Was thinking about having four channels per arch and for ease of storage I was going to wrap 1 1/2 pvc in 2 foot increments to slide over the base structure instead of just wrapping the entire 1" EMT. Any thoughts or advice would be great. Thanks.
    Jan 2009
    Eagan, Mn.
    4,074
    Default Re: First Time Arch Builder
    There is a how to filed here somewhere about arches with replaceable sections. I think it was 8 channel. And it was using mini lights but you could check out the construction. I don't remember if it's in the Wiki or files area.
    Aug 2013
    Surprise, Az
    621
    I think you would be disappointed with 4 channels... I don't think it would give the desired flowing movement. Consider changing to 8 channels.
    1,564
    The construction method that I found and followed was to use 10' - 1/2" PVC for the arch and 3/4" thinwall PVC for the sections, 8 sections @ 15", each will hold a 100 count minilight string.
    With the EMT you will have to have it pre-formed in the arch shape and you may find it difficult to slide the 1-1/2" PVC, especially if you only have 4 segments (30" long, assuming a 10' emt). With the PVC you slide the sections on the core and then secure one end ( 12" rebar about 6-8" in the ground) and then bend the other end to a second rebar anchor about 6-7' away from the first. The PVC will flex fine and I have found that I do not need any additional support.
    If you are concerned that @ 3/4" they won't be large enough, once you wrap the lights, they are about 2 - 2-1/2 across and w/ 100 minilights very bright.
    Oct 2016
    49
    My driveway is 16' across. My biggest concern was strength and flexibility. The emt seems to bend just fine. I did one test piece. Haven't wrapped it with lights yet.
    Jan 2009
    Eagan, Mn.
    4,074
    I know pvc can be purchased in 20 foot lengths at some plumbing distributers. It might be long enough to get by.
    1,564
    OK did not realize you were building an arch across your driveway, that is a big difference, not only in length of the arch but height to drive under. I think you were right to go the emt route. You could use 2 straight section of emt to get to a 6-8' height on each side then attach a curved arch piece between the uprights, they are going to need to have some guide wires or braces for support. I have seen one where at the top of the uprights they attacked 4 way connector and ran support braces between the arches and w/ an additional 45 elbow on the end ones, a brace to the ground.
    The other issue to consider w/ emt is, its metal, and in wet weather could cause a ground short, (something I have to consider w/ my tomato cage minitrees) so you may want to see if you can find a insulate it. You may consider trying something like Flexseal (the stuff they hawk on TV, paint on screendoor in boat bottom and no leaks) and paint it on the emt (they have spary-on and brush-on) or Plasti Dip to provide an insulating barrier between the lights and the emt.
    Quote Originally Posted by submarine guy View Post
    Dec 2010
    Florence, SC
    140
    Instead of painting on "insulation" go to a dollar store near you and purchase the floating Styrofoam tube "thingy" for less than a buck and slide them on the emt, also works great to insulate the water lines in the crawlspace of your house, no one can see the color under the house.
    BillW
  9. Thanks Ruppro thanked for this post
    Likes Ruppro liked this post
  10. #9
    1,564
    Quote Originally Posted by BillW View Post
    BillW
    Mine recently had theirs on sale for $0.18 apiece, knew I needed them for something, should have grabbed the box full. lol
  11. #10
    Oct 2016
    49
    Great ideas
