Results 1 to 2 of 2
Thread: Light wiring question
    Buffalo, NY
    857
    Default Light wiring question
    I have 8 light up skull lights I have used on my walkway for the last few years. They use c7 blubs inside the skull, and are all on 1 wire.
    I bought some zip cord and sockets because I want to make them controllable. Originally, i was thinking I needed to make 8 cords, each going to a different skull, and having both the line and the neutral. Then I got to thinking, that with the SSRs, only the line comes out of each, there is no neutral back, to the SSR itself. So I am thinking I can run a single wire from the last skull back to the outlet, and it will work fine. I did an attempt at a sketch attached below. I know it's not a standard electrical diagram, but I hope it gets the point across. The solid lines are for the line (hot) wires, and the dashed lines are the neutral wires.
    Anyway, I think that will work, but wanted to get someone else to look at it before i make it or blow something up testing it.
    Attached Files Attached Files
    1 channel, 0 dimmable. Powered by a man flicking a lightswitch to the beat.
    Bastrop, Texas
    978
    Default Re: Light wiring question
    That'll work just fine.
    Bob
    I love the smell of solder flux in the morning....smells like Christmas magic...Set up Done!! Showtime!!
    (for the fruit of light is found in all that is good and right and true) Ephesians5:9
