Something like this....
So I just received a new Sun Hokey Prusa I3 Acrylic a couple of days ago. I've managed to test print several items (Cube, Spiral vase, I simple design of my own), but haven't been able to figure out how to activate supporting for models that are printed from the bottom up that have areas outside the original support structure. Like I said, I'm new to this so I'm not really familiar with the terminology. If you would, imagine a wolf. It's paws and legs are going to print first, followed by it's body, then neck, head, and tail. How do you support the nose of the head and tip of the tail if they are in the downward position like it's eating? Not quit level with the printing base plane, but far enough away from the main model not to connect.
I really hope this makes sense, kind of confused myself.
Any ideas?
Oh Yeah, I'm using Repetier-Host V1.6.2 for printing. I'm also using Slic3r.
"There's no such thing as a dumb question, except for the question that was never asked!!"
Mark
2014 4 channel Mr. Christmas unit, 3,000 lights.
2015: 32 channels, over 7000 lights including 4 singing faces! (updated)
2016
Who the heck knows, I don't!!
[url]http://pavukchristmas.com[/url]
Mark
2016
I actually saw that and tried it to no avial. I'll read through it again. More than likely I missed something!!
Thanks!!
Mark
2016
here's the other issue I have, Even though I've calibrated the print table numerous times, I get un-even printing. My thought is not enough flow. Is that right?
Mark
2016
Search YouTube for prusa i3 Estep calibration.
Thank you for pointing me in the right direction!!
It can get a little crazy when you're trying to learn something new while trying to get your lights ready for the year!!
Mark
2016
One trick is to print in an orientation so that there are no overhangs, as these are called. e.g. stand your wolf on its nose or the tip of its tail, and print it like that (with a "brim" to spread the contact area). That's not always possible.
Otherwise, in Slic3r under "Printer Settings" there is a tab for "Support Material"... check the "Generate Support Material" checkbox and Slic3r will automatically build structures underneath the wolf's head and tail and anywhere else there is a significant overhang. Slic3r leaves a weakness just below the actual object, so that it is easy to remove the supports.
Whew, spent most of the day working with supports for overhangs. Finally have it figured out. In Slicer, go to "configuration", then under "support material" select "generate support material" and set "0" (zero) for both "overhang threshold" and "enforce support for the first". Slicer then determines where it needs to provide support for your model. In my case, I selected the pillars pattern. There are seceral others that would work better depending on your model.
Also, Slicer does show the support in the preview after slicing the project.
Thanks for all of your help!!
Mark
2016
