Results 1 to 10 of 12
Thread: PVC Arch.
    Dec 2015
    47
    Default PVC Arch.
    Super simple, Super cheap.. Only other thing i could do is upgrade pixels. 3 pixels per still looks ok. I love the light dispersion from the pvc.
    Dothan, AL
    112
    Default Re: PVC Arch.
    I'm curious on the PVC size, schedule, how you shaped it without it kinking, etc....
    Sent from my Nexus 5X using Tapatalk
    Aug 2013
    Prairieville, LA
    821
    I have used the "sharkbite" tubing because it is readily available at my local HD. I, too, really like the diffused look. I have used 30 LEDs/m strips in there and they pull thru quite nicely. I am not 100%, but I think the tubing is 3/4". It comes in 50' rolls, so kinking it is not a problem at all!! It wants to keep its rolled shape.
    Dec 2015
    47
    These are 3/4 pex sticks white. I used a heat gun and slowly formed it in the arch shape. I was going to try hot water to soften but there is a fine line when heating. Too hot it kinks not hot enough it stays the same.
    Jan 2014
    Palm Bay, Florida
    1,445
    my sharkbite, 1 inch, arches, bends with no heat
    Nov 2015
    Milwaukee
    2,225
    Same here, no heat. Just hand bent to shape.
    Southern IL
    943
    Most places you can just lay it the sun for a little bit to help but if you're using 8-10' you shouldn't need to do anything
    Sep 2016
    21
    What did you use for the base to keep these in place?
    Nov 2015
    Milwaukee
    2,225
    Quote Originally Posted by PeteyMoon View Post
    Who are you asking?
    If me, I used 18" pieces of suspended ceiling hangar wire bent into a u. Two per leg, one close to the arch, one out at the end of the leg. You can get the wire at home depot $17 for a bundle of 50 6' pieces.
    Jan 2014
    Palm Bay, Florida
    1,445
