Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 63
Thread: P10 help guide
  1. #31
    Framingham, MA
    430
    Default Re: P10 help guide
    Quote Originally Posted by Rob Baldwin 12 View Post
    Yep there is either 1 or 2 arrows on each board the one pointing to the short end of the boad is the data path... the one pointing to the long end of a board is the boards orientation ... the orientation is the arrow that you follow when setting up fpp. Again beaglebones and the octoscroller cape have 8 panels per output and 8 outputs... the pi and the pi matrix adapter has 12 panels per output and 3 outputs.
    FYI: My latest BBB image increases the max to 12 per output for a total of 96 panels. Also just got the 1/4 scan outdoor panels to work.
    Dan Kulp
  2. Likes MrSmoofy liked this post
  3. #32
    Jul 2014
    Missouri
    112
    Where did you buy your outdoor panels? I have been wanting to do a 6 x 6 setup that runs 24/7, but was waiting until the BBB could do the outdoor panels. The indoor panels with Plexiglas covering them are not very bright on a sunny day.
  4. #33
    Framingham, MA
    430
    Quote Originally Posted by jwamsley07 View Post
    I just popped on ebay and found something relatively cheap and free shipping:
    http://www.ebay.com/itm/P10-LED-Disp...72.m2749.l2649
    I only grabbed two of them as I have no plans on using them for anything other than testing.
    Dan Kulp
  5. #34
    Tampa, FL
    1,336
    The back of those are not waterproof based on the images
    Sent from my SM-G935V using Tapatalk
    Chris
    Holiday Lighting, LLC
    Your Source for Genuine Mean Well Power Supplies
    https://holiday.lighting
    https://facebook.com/holidaylightingllc
    @holidaylightin9
  6. #35
    Framingham, MA
    430
    Quote Originally Posted by MrSmoofy View Post
    What I received doesn't look anything like those pictures. Everything is definitely coated in a shinny clear coating.
    Dan Kulp
  7. Likes MrSmoofy liked this post
  8. #36
    31
    i have done all the above and still cannot get lights. BBB powers correctly. All power and connections correct for p10 panels. Fpp.local/ finds the BBB. The only thing i cant check is the octoscroller. The light comes on the octoscroller but how do i know if its damaged?
  9. #37
    31
    Hey Rob,
    I cant seem to get the xlights to run as well. I used the above directions. Im in bridge mode. Im not running a pi as of yet, should it be in that mode or standalone? Also i have 3/3 panel. using 3 outputs on octoscroller. can u give me what my setup would be in xlights? Also im using 192.168.0.12 for add. When i make e1.31 in unicast i get nothing
  10. #38
    Nov 2014
    Close to Hillsboro, OR
    249
    Okay, time for a couple silly questions...how do you get your BBB and scroller cape connected up and how do you do a test on your P10 matrix? I'm guessing that the small wire pair that comes included in the DIYLED kit connects to your 5V P/S and then to the terminal block on the octoscroller cape? What settings do you do inside FPP to get it to output a test pattern, or do you have to do the test pattern within XLights or Vixen?
  11. #39
    Austin, TX
    33
    I did a video & talk about the issue I had with one configuration. Let me know if it helps.
    https://www.youtube.com/watch?v=WPl8...1bHOdf&index=6
    Jeff
  12. Thanks Stormyblade thanked for this post
  13. #40
    Nov 2014
    249
    Quote Originally Posted by JeffL98 View Post
    Jeff
    That video was VERY helpful. For instance, I was scratching my head wondering how I was going to supply the 5VDC to the BBB+Octoscroller cape and I didn't realize the terminal block on the Octoscroller was enough to power both units. Also, I did do more searching and found out that FPP has a test pattern/mode built in, so you have another option besides just trying to do bridge mode via Vixen or XLights. I went back and watched your entire video to see how you had hooked everything up as well.
    With my matrix being set up as a 3x3, it looks as if I'm going to be using 2 outputs from the Octoscroller - 1 output going to 1 panel and the other output going to 8 panels. I could probably try to split it up to a 4 & 5 configuration, but it will probably be easier to simply do 8 + 1.
    (Edit: spelling)
