Results 1 to 7 of 7
Thread: 240v AC SSR system suggestions
    183
    Default 240v AC SSR system suggestions
    been looking all over for a cheap ssr dimmer solution that definitely works on 240v.
    my googling in this case failed.
    Looks like some of the renard stuff "might" work.. but the info I found don't give me a solid "it works on 240 with no issue"
    can you guys recommend some controllers/boards for me?
    I'm ultimately hoping for a single board that can do 8-16 strings that are using various off the shelf AC light strings. not sure avg current draw cause I'm used to pixels.
    Gunna combine my pixels with some guy that has lots of static AC light strings.
    my preffered protocols is
    SACN / e1.31
    dmx
    renard
    in that order. won't use LOR (I have a custom made sequencer and I hate LOR protocol and won't use it)
    9,259
    Default Re: 240v AC SSR system suggestions
    I'm not embarrassed to say that I've wondered the same thing for many years, and I've never really explored it because where I live, we use 115-120vac. I've dummied-up a picture that show the difference as I understand it, but I may be off my rocker here... so I'm looking to the expert electricians out there to review it and chime in. Anyone?
    http://digwdf.com/store/
    Jan 2014
    RAF Wittering
    273
    I can guarantee that the renard plus tr8 tr16 and tr24 work perfect in 240v
    I live in the uk and I have two tr24's I got from radiant-holidays.com and told them it was for 240v use and sent out the different resistors needed for the triacs
    Brilliant service and help
    2016 pixel power RAF Wittering soon to be RAF Akrotiri
    Second new house in 12 months
    Jan 2014
    RAF Wittering
    273
    duplicate deleted
    9,259
    Quote Originally Posted by kartingted View Post
    I'm told by the Renard-Plus guys that they generally provide a 360-ohm, 1/4 watt resistor for folks that need 240 such as yourself. Or was it 1/2 watt? The TRIAC gate doesn't require a whole lot of current to open the flow, so I'm thinking the 1/4 watt is probably all that's necessary.
    Jan 2014
    RAF Wittering
    273
    Off the top of my head I can not remember. Built them over a year ago now.
    There was the gate resistor change and the transformer bridge for 240v and that's all that I done and it's worked perfectly
    Radiant holidays send the resistors that you need to change out with the kit
    If I was going to buy ac boards again I would go straight to them and buy another one.
  7. Likes TazChaLet liked this post
  8. #7
    9,259
    Ok, thanks. It's probably 1/4 watt.
    BTW, if you haven't checked them in awhile, they have quite a few new things in their cadre of cool stuff. http://renard-shop.com/
    You might find something there that you can plug into your existing RP gear and go Wi-Fi, or pixels, too.
