Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: [SOLVED] Vixen x64
    53
    Default Re: [SOLVED] Vixen x64
    Yea I got em thanks. The update file did not work but the full release did. Wasnt on there last time I checked. Looks to be working now though. Thanks!
    53
    Tried audio visualizer... got this
    System.BadImageFormatException: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
    at FMOD.Sound.FMOD_Sound_GetFormat(IntPtr sound, SOUND_TYPE& type, SOUND_FORMAT& format, Int32& channels, Int32& bits)
    at StandardSequence.StandardSequence.ParseAudioWavefo rm()
    at StandardSequence.StandardSequence.toolStripButtonW aveform_Click(Object sender, EventArgs e)
    at System.Windows.Forms.ToolStripItem.RaiseEvent(Obje ct key, EventArgs e)
    at System.Windows.Forms.ToolStripItem.HandleClick(Eve ntArgs e)
    at System.Windows.Forms.ToolStripItem.HandleMouseUp(M ouseEventArgs e)
    at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEven tArgs mea)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ToolStrip.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    53
    and the waveform....
    Bixby, OK
    9
    I updated the files in my first post. The visualizer is working; however, the waveform and frequency spectrum still are not. For some reason they do not display the actual error that occurs so I'm going to have to get some more code from KC. I'll post the latest fix whenever I come up with it. Thanks for letting me know about this bug.
    [url="http://nfusetechnology.com"]nFuse Technology[/url]
    53
    Thanks that will help alot!
    Massachusetts
    150
    Smile Re: [SOLVED] Vixen x64
    im running xp and that fixed my problem to, i got the exact same message so its not just on vista
    Dec 2008
    1
    If I try to run the, with your mod modded, version of Vixen, I receive this Error-Message (german):
    I'm sorry, but Vixen is about to die. Please take a screenshot of this message.
    Methode nicht gefunden: Int32 FMOD.fmod.get_DeviceAssigned().
    bei Vixen.Engine5..ctor(Host host, Form nullableKeyInterceptor, PlugInRouter nullableRouter)
    bei Vixen.Form1..ctor(String[] args)
    bei Vixen.Program.Main(String[] args)
    OK
    I hope, you can help me :-(
    My System is Windows Vista ultimate x64
