Results 1 to 10 of 17
Thread: [SOLVED] Vixen x64
    Bixby, OK
    9
    Default [SOLVED] Vixen x64
    Some users have had problems getting Vixen to work in 64-bit versions of Windows. After working with K.C. the problem has been solved. The issue lies in Fmod and has been corrected.
    To fix any issues on x64 operating systems: unarchive the attached files and copy into the Vixen directory. The included files work on 32-bit and 64-bit versions. I am sure they will be included in a future Vixen update, but until then the files are available here for download.
    NOTE: This update is for Vixen 2.0+ only.
    Attached Files Attached Files
    [url="http://nfusetechnology.com"]nFuse Technology[/url]
    southeast iowa
    524
    Default Re: [SOLVED] Vixen x64
    I knew KC would get it done. I worked on him breifly until my "cough" trial "cough" of vista x64 died.
    Mahopac, New York
    353
    Smile Re: [SOLVED] Vixen x64
    I tried the fix and it worked great using the adjustable preview plugin. Thanks to KC and yourself for getting this done. It will come in handy being able to use my Vista PC as a backup for my Halloween display, if necessary. Now, once wjohn finishes the Triks-C project, I may just run my Christmas show on one PC running Vista. :D
    Thanks again to everyone involved, kudos for a job well done.
    Melbourne , Australia
    896
    This is fantastic news.
    hopefully KC will get this and the enttec open fix together into a new release and ill be able to use it for my show this year.
    fingers crossed.
    53
    Ah... Im not having such luck! I copied it in and got
    Method not found: 'Int32 FMOD.fmod.get_DeviceAssigned()'.
    at Vixen.Engine5..ctor(Host host, Form nullableKeyInterceptor, PlugInRouternullableRouter)
    at Vixen.Form1..ctor(String[] args)
    at Vixen.Program.Main(String[] args)
    53
    update will not work either...
    Bixby, OK
    9
    Quote Originally Posted by thedudedrummer View Post
    That looks like it error is coming from a plugin. What plugins are you running? I cannot find a get_DeviceAssigned() function anywhere in the code. I wonder if something was lost in the conversion. Either way I can help you solve this.
    NOTE: This plugin is for Vixen 2.0+. If you have 1.0 it will not work.
    53
    Im trying to install version 1.1 because the file for 2.0 I found was just an update, and it will not launch... Is there a full release version of 2.0 available out there?
    53
    Nvm... think I got it figured out... will attempt to get it working when I get back from school tonight... thanks again for releasing this!
    Ft. Walton Beach, FL
    1,502
    Hmmmm.. Let me think.... Where would I look for a Vixen release?....
    How about the Vixen/Release Information sub-forum.
    And heres the thread.
    http://www.doityourselfchristmas.com...ead.php?t=2648
    RavingLunatic
