Results 1 to 7 of 7
Thread: Base for Mini Trees
    Jan 2014
    Palm Bay, Florida
    1,436
    Default Base for Mini Trees
    I had problems with the mini tree staying up right. I built a base out of 1/2 in. PVC
    Jan 2008
    Kennesaw, GA
    926
    Default Re: Base for Mini Trees
    I saw another post where loose but connected zip ties were put in some bottom holes and then a stake pushed in the ground. In my case I had them sitting on top of a short brick wall around some flower beds and luckily they never got blown over. This year I'm moving them out into the yard so that might change things on the wind hits them. I appreciate the idea.
    Jim Nealand
    Kennesaw, Ga
    Jan 2014
    Palm Bay, Florida
    1,436
    Zip ties are on mine, two sides and front. Saddle tee is for snapping on my Arch cross bar, removable to insert free standing base.
    Free standing: BaseFreeStanding.jpg
    Jan 2014
    Palm Bay, Florida
    1,436
    Jan 2009
    Eagan, Mn.
    4,073
    I'm going to use a zip tie on each side and two stakes. I left the bottom two rows empty for snow.
    1,048
    That's why I got the 360 degree minis. They stay upright even in high winds without using any stakes.
    James
    Sent from my SM-G900V using Tapatalk
    Sep 2015
    Donbass, USSR
    31
    Hi all!
    Sorry for pore English.
    I have made mini tree 180 degree, 6 strands, 50 pixel/strand, 60 led/meter strip.
    Base made from PVC. As diffuser I want use corrugation tube from plumbing fixture store 4cm diameter.
    Some photos you can find in cloud folder: https://cloud.mail.ru/public/AHak/t7Zfezred
    Now I have troubles with lighting: some flickering and slow motion. And upside element has bad shadows. I will change strip configuration there.
    When I fix it (hope next week) - I'll upload video of complete project's look.
    May be it will be helpfull for somebody )
  8. Thanks Phil Spencer thanked for this post
