Results 11 to 20 of 49
Thread: How Do I Mount Pixel Frames Around Windows?
    Winter Haven Florida
    2,562
    Default Re: How Do I Mount Pixel Frames Around Windows?
    the pvc clip attached too the double sided tape and the tape too the window frame but like Mind said a clap or something where the screen goes may work also think outside the box
    James WinterHaven Fl
    Southern California
    89
    Quote Originally Posted by MindTrik View Post
    The only thing I've got is to take the screen out and possibly create somthing that used the screen channel. Heavy duty suction cups should work though...have you tried the big ones?
    Sent from my LG-H811 using Tapatalk
    I don't know if the suction cups were big, but they were the most heavy duty that Lowes had. You press them on the window and then crank down the hook. I put in on my window as a test with a 5 pound weight and it fell off in a couple of days. They use suction cups to carry large panes of glass so I don't know why a suction cup wouldn't work. Maybe I need to find a stronger one.
    Southern California
    89
    993
    Maybe something like these, but may need to use regular double sided foam tape for extra strength. And being white or clear you may be able to leave up.
    http://www.command.com/3M/en_US/comm...4529207&rt=rud
    or
    and zip tie frame to them.
    Long Lake, New York
    734
    Quote Originally Posted by Chris A View Post
    I used to work with large pieces of glass and used the suction cups for glass that you mention. We had to handle big pieces of single pane as well as insulated units with raw glass edges.
    The suction cups for glass have levers on them to apply suction as well as many places will use a solution of water with a bit of dish soap (or similar) to increase adhesion. The suction cups for glass are "usually" 6 inches in diameter or more to allow enough surface area to "grab" the glass.
    Another thing to watch out for is that these type of suction cups can literally (had it happen a couple of times) suck so hard that they can break the glass! Just so you know.
    Jan 2014
    Palm Bay, Florida
    1,373
    I used screen frames. 011646714671lg.jpg011646714435lg.jpg100_1821.jpg Home Depot sells spring clips for each corner http://www.homedepot.com/p/Prime-Lin...-100536660-_-N
    Southern IL
    927
    Anything overhead that you attach wires to? Could then suspend the frame from above and use suction cups or mounting tape on the bottom to keep it from flopping around. I also seen a post recently where someone uses eyelets and 100lb fishing line to hoist/suspend their lights on pvc to their eaves. Possibly thread the fishing line through the edges of the window and attach from the inside of the house.
    Mansfield, TX
    86
    HOT GLUE!!! I'm just kidding... maybe.
    Southern California
    89
    Quote Originally Posted by markrvp View Post
    I did test using hot glue on a suction cup by putting it on an old picture frame glass. it did work but i was concerned about maybe damaging the window.
    Dec 2015
    Shadow Hills, CA
    141
    I have the same issue at my house, I ended up hot gluing clear hooks to the stucco. It worked well and with them being they are only visible close up. My intention was just to leave them up year round but once summer hit they fell down with no damage to the stucco.
