Results 11 to 20 of 29
Thread: PixaBulb Flush Mount
    Nov 2015
    Milwaukee
    2,225
    Default Re: PixaBulb Flush Mount
    If anyone has a dead one, you can send it to me and I can adapt the design.
    Eagan, Mn.
    4,073
    PM me your address and I'll send a sample. Note all gece use the same base. G35, g60, g90, icicles, snowflakes, etc.
    Nov 2015
    Milwaukee
    2,225
    That's an excellent design. I'm thinking its time for you to cast that sample and transition over to DIY injection molding.
    You are evil sometimes. You know that. You put a bug in there and it just gnaws at your brain. Its insidious sometimes.
    I just ordered this:
    I am hoping I can leverage all the scrap ABS from the 3D printer, melt it down to use it for injection molding.
    Now I gotta figure out where to put the darn thing. So not putting it down in the basement with dozens of pounds of gunpowder (reloading).
    St.Louis mo
    1,608
    Default PixaBulb Flush Mount
    Just get one of these
    Nov 2015
    Milwaukee
    2,225
    Yea, sure, lets get even bigger $15k and huge. No. Not happening. And it uses the wrong plastic (polyproplyne wax I think). And yes, I actually had looked into finding a used one thinking it would be cheap and automated. Automated, yea. Cheap? No. With its design it couldn't ever be used as an injection molder. Its simply not designed for that.
    7,762
    Oh wow. Look what i started. I'll admit that it was a very half cocked comment on my part. Nonetheless, I'm very interested in seeing your results with this. It's always seemed to me that DIY injection molding should be a more common thing. I haven't seen the unit you linked but I have seen completely DIY designs that use a harbor freight arbor press and some plumbing parts and a heater coil. It looks a lot like this device.
    --Jon Chuchla--
    Jan 2014
    Morganton,nc
    155
    I am wanting to use these for some frames I built however the frames are 1 inch square tubing. Is there anyway the wire slots can be modified so they are in line with the mounting tabs?
    Sent from my SM-G920V using Tapatalk
    Nov 2015
    Milwaukee
    2,225
    Yes, that can happen.
    Need daylight hours after work for some outdoor stuff. But once its dark tonight (barring granddaughters and their homework), yes I can pop upstairs, load the mesh and rotate it for you.
    Jan 2014
    Morganton,nc
    155
    Thanks. It will be a great help.
    Nov 2015
    Milwaukee
    2,225
    Ok, there is a new model on thingiverse (Same url: http://www.thingiverse.com/thing:1681035 ). Added a rotated version per rlemery's request.
    Let me know if that will work for you.
