Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
Thread: "Poor Mans" $3 Sharkbite Light Arch Base How To
  1. #31
    Sep 2016
    21
    Default Re: "Poor Mans" $3 Sharkbite Light Arch Base How To
    [QUOTE=nailhead_ford;425680]So I have made a “poor mans” version to make a light arch base that I will share with you. Materials are less than $3 bucks and takes a small bit of modifications. These definitely don’t look as good as the bases sold by lightsonmontague at http://doityourselfchristmas.com/forums/showthread.php?42850-Sharkbite-arch or livinglightshows at http://doityourselfchristmas.com/forums/showthread.php?42362-HDPE-Arch-Kits&highlight=livinglightshows, but you get what you pay for!
    [QUOTE]
    How did you bend the sharkbite to fit your design? Thanks
  2. #32
    Dec 2015
    San Antonio, TX
    79
    [QUOTE=
    How did you bend the sharkbite to fit your design? Thanks[/QUOTE]
    I would like to say because of my brute strength, but in reality sharkbite is flexible.
  3. #33
    Eagan, Mn.
    4,073
    Quote Originally Posted by nailhead_ford View Post
    1/16" out of a schedule 40 fitting is barely putting a dent in it.
    Sent from my HTC One_M8 using Tapatalk
    I agree it's not much, but if it "really" bothers you buy schedule 80.
  4. #34
    Palmdale CA
    143
    BOM For 1” sharkbite
    2 – ¾” PVC ‘T’ connectors
    2 – ¾” PVC elbows
    1 – ¾” PVC schedule 40 tubing
    ¾” stainless self-tapping screws or equivalent
    You can replace the two elbows for ‘T’ connectors if you would like to daisy chain your arches.
    Directions
    1” sharkbite is 1/16” of an inch too large to fit into the ¾” fitting. You will need to take a dremel to open up the hole in the ‘T’ fitting so the sharkbite will fit snug but not overly tight or loose.
    I cut two 3” long pieces of the pvc to connect to the ‘T’ fitting holding the sharkbite to the elbow.
    The spreader cut to desired length for your arch.
    Use self-tapping screws to secure the spreader bar to the elbow. You could solvent weld the spreader to the fitting, I just wanted my easy to dissemble.
    Grate job
    Is the bigger arch a 2'' and the little ones 1 " and how many pixels are going to use in each one and how are you wiring them
    Thanks Bob
    KEEP HI AND DRY
  5. #35
    Dec 2015
    San Antonio, TX
    79
    Quote Originally Posted by bob81354 View Post
    Grate job
    Thanks Bob
    You are correct.
    Large - 2" HDPE, 10' long, 29 - 30/10 pixels
    Med- 1" shark bite, cut to fit to follow curves don't remember exactly length, 21 - 30/10 pixels
    SM- 1" sharkbite, 5', 15 - 30/10 pixles
    All larges wired in series on 1 output
    All mediums in series on 1 output
    All smalls in series on 1 output
    I have a total of 4 triple arches running on a seperate e682 channel. If you had a pixlite or falcon I am sure you could zigzag on 1 output pretty easily
    Sent from my SAMSUNG-SM-N920A using Tapatalk
  6. #36
    Sep 2015
    19
    Built these and they look great!
    Don't suppose you also got a real cheap way of anchoring these down so they don't blow over in the wind?
  7. #37
    Dec 2015
    San Antonio, TX
    79
    Quote Originally Posted by snooze091 View Post
    I used these aluminum tent posts that have a hole in the top. Cost about a $1 per. Put a zip tie through the hole and around a leg. Push into the ground. Used 2 per arch. Bought at Dick's sporting goods.
  8. #38
    Dec 2015
    San Antonio, TX
    79
  9. #39
    Dec 2015
    San Antonio, TX
    79
    /*Deleted*/
  10. #40
    Palmdale CA
    143
    Hi
    how are you going to hold down the lights in the 1" sharkbite and when you say your running on a separate e682 channel do you mean all the arches
    KEEP HI AND DRY
