Results 1 to 7 of 7
Thread: Ren-C and Ren-T - Compatible?
    Sacramento, CA
    353
    Default Ren-C and Ren-T - Compatible?
    I haven't been following the Renard standard pin outs. So I out of the loop on the following:
    Will WayneJ's Ren-T board RJ-45 pin out match up to the following:
    1 - Provide Power to the Ren-C
    2 - Provide Zero Crossing to the Ren-C
    3 - Provide Power to the downline Grinch board (on the other side of the Ren-C)
    I didn't do any homework, was thinking someone close to these projects already knows this.
    ms
    Matt Stemple
    Melbourne, Australia
    1,079
    Default
    Matt,
    the RENC draws 5VDC from the GRINCH/595 via the IN RJ45. The GRINCH/595 need it own 5V DC Power Feed via J2 on the controller.
    The RENC needs a ZC signal, you can do this with the RENT or a power supply based on that design. (CT transformer, two diodes and a Capacitor.
    The 'downstream; GRINCH/595 need it own 5V DC Power Feed via J2
    [B]John[/B]
    [url]www.xmasinmelb.com[/url] General Site
    [url]www.xmasinmelb.com/zencart/[/url] Online Store
    [SIGPIC][/SIGPIC]
    5,343
    Default
    The capacitor is used on the power-supply side of things, not the zero-crossing side. All that is needed for the zero-crossing is the transformer, diodes, and connectors/wiring.
    Sacramento, CA
    353
    Default
    I have got access to a simple ZC design supply that was part of the horning dimmer design. I will just dig that out. I plan to power the grinch(s) with a DC output wall wart that I have cheap access to.
    ms
    Matt Stemple
    Sacramento, CA
    353
    Default Pins 7/8 for ZC
    I am not clear why there are two pins used for zero crossing? Based on the schematic of the Ren-T it appears that they are tied together.
    ms
    Matt Stemple
    Orlando Florida
    338
    Default
    Can you use one Ren-T for multiple Ren-C boards or do you need to have one for each board?
    5,343
    Default
    If the Ren-C boards are daisy-chained together, one Ren-T will work for both. Basically, you will need one Ren-T per serial port in this situation.
