Results 11 to 20 of 37
Thread: E682 irmware for RGBW Pixels
    Oct 2019
    University Place. WA
    66
    Default Re: E682 irmware for RGBW Pixels
    I decided to try the Sandevices way of updating so I reverted back to 4 using my prop plug and then used the FWloader to install 5.030. Worked as it should even using refresh but I rebooted anyway.
    One way to tell if it's update is the LEDS. The single green LED next to the red one will go out. After the update that green and red LED will flash back and forth.
    Yes I'm am getting all of those indicators as I did exactly as you described, the problem is I don't get the alternating red/green leds after the initial green goes out.
    Love LEDs!
    Kansas City Missouri
    2,575
    Quote Originally Posted by TomsLEDs View Post
    Make sure your sequencing software isn't running. I'm not familiar with Xlights but Vixen outputs to controller even when you're not playing a sequence unless you turn off output to controllers or close Vixen. Since the green and red lights aren't flashing back and forth then it isnt installing for some reason. The instructions have a few things you can check. No indication in Last Firmware Status Update window?
    Oct 2019
    66
    Here is what I see when the process starts, and when it terminates.
    Love LEDs!
    2,575
    I'm all out of suggestions. It appears the eeprom is not accepting info. Only thing I can suggest is contact jim@sandevices.com.
    Oct 2019
    66
    Thanks. Yes I stated a trouble ticket with him. I may just have him flash an eeprom and I will solder in another. It was a kit I built.
    Love LEDs!
    2,575
    Do you have an 8 pin socket? If so solder that on the board and then you can easily remove when you need too. I use sockets on all ic's and network resistors.
    2,575
    Probably should mention. Resolder the contacts on the eeprom and try updating again. May have a bad solder joint. Just a thought.
    Oct 2019
    66
    Thanks, that's easy enough to try.
    Well that did not help me, but it was worth a try. Just waiting on Jim now.
    Love LEDs!
    2,575
    There's also a phone numbed you can contact him at. I've called him a few times. If you contact him and get it resolved make sure you post it here for anyone having the same issue.
    Jul 2012
    Novi, MI
    412
    This would have been good to post earlier in the thread. Has the card ever worked to control pixels? Does any configuration information get saved when you change and save it?
