Results 1 to 9 of 9
Thread: New to vixen
    Dec 2015
    15
    Default New to vixen
    I was attempting to make a sequence and play the music, however vixen is stating that there is an export error and no plug in. When making a sequence do I have to have my arduino plugged in ? If not how do I change that thank you
    2
    Default Re: New to vixen
    I use adjustable preview as my output when I'm not near the arduino.
    Feb 2008
    Warminster, PA
    1,744
    Quote Originally Posted by Davegris View Post
    If you have a plugin setup for (for example) a com port, Vixen will look for the com port when running the sequence. If you don't have the com port connected, just go into plugins and disable it(uncheck the checkbox).
    Chris
    Eagan, Mn.
    4,075
    The wiki has a list of setup videos for Vixen 2.1 I would suggest going through them. They might be too basic but they cover pretty much everything.
    Aug 2017
    3
    how to fix this problem? the percentage is blurred
    Eagan, Mn.
    4,075
    Quote Originally Posted by fatima4 View Post
    Everything looks good. The visualizer is grayed out. Is that what your talking about?
    Sent from my SM-G930V using Tapatalk
    Aug 2017
    3
    yes. how to fix that?
    Aug 2017
    3
    yes. how can i fix that? thank you for your response
    Winter Haven Florida
    3,039
    add a song and if it doesn't show right after that click the button on the left of it look at picture the red arrow points to it
    James WinterHaven Fl
