Thread: Outdoor 6 outlet power stake wiring
    57
    Default Outdoor 6 outlet power stake wiring
    Good evening. I have this Woods 6 outlet outdoor timer that won't work electrically.
    I took it apart and found the following. Two main wires, one each on a side of a side of a micro switch and then another thinner wire to a coil and then one small wire from the coil to one side of the micro switch.
    I think that the two main wires are the power to the switch. I want to just make this n on all the time timer and would like some advice about wiring it. I want to eliminate the coil part as well as the switch.
    Any suggestions would be appreciated
    Wayne
    NE Pennsylvania
    200
    Default Re: Outdoor 6 outlet power stake wiring
    A pic would help. Most likely the micro switch is breaking the hot line. If that's the case you would connect those two wires for constant on. If you carefully activate the switch, do the outlets power up?
    2013 - 6,000 Incans all static, 1 mega tree
    2014 - 12,500 Incans all static, 27 wireframes, 3 mega trees
    2015 - 20,000 Mostly LED, 45 wireframes, 4 mega trees, 72 renard channels, 16 LOR channels
    2016 - 25,000+ lights mostly LED, 50+ wireframes, 4 mega trees, 176 renard channels, 16 LOR channels, 800 pixels
    https://www.facebook.com/Stoney-Ridg...6107967233852/
  3. Thanks Christmasnut thanked for this post
  4. #3
    57
    Thanks so much. Rewired those to leads together and it works like a charm.
    Wayne
