Results 1 to 8 of 8
Thread: Looking for a simple solution for static setups
    Aug 2012
    Forest, VA
    452
    Default Looking for a simple solution for static setups
    I'm still learning a lot in this hobby and I appreciate all of the help from this community.
    Since I am convinced that I have seriously over maxed my Dirkcheap SSRs and fried a few of these. Here is what I need if someone can point me to the right solution.
    I was reading this post on "Latching Circuit" and someone suggested to just use a Renard channel to switch on a Relay.
    That is exactly what I need except I will be turning on a power strip. I have a few static displays with a bunch of lights in them and I would like to turn them on at the beginning and off at the end of the show. Nothing fancy and no dimming is needed. Just on & off.
    Thanks!
    Buddy
    Sep 2013
    Seattle, WA
    1,116
    Default Re: Looking for a simple solution for static setups
    Aug 2012
    Forest, VA
    452
    Thanks @deonb!
    For the Relay itself it does look like it has the muscle to do the job.
    What else would it need? RJ45, etc?
    Buddy
    Aug 2012
    Forest, VA
    452
    Thinking outside of the box here.
    Would this be a matter of reusing a circuit channel from an SSR like Dirkcheap and then adding the appropriate Relay?
    Again, my goal is to use one of my Renard channels for turning it on/off. The Relay would then activate my power strip which could have between 4-8 amps of lights (ball parking this estimate since I don't have specs on these static icans).
    I know I'm not an electrical based person but I am willing to do the work.
    Buddy
    Sep 2013
    Seattle, WA
    1,116
    Quote Originally Posted by UBotBuddy View Post
    Yes, you just directly substitute the Dirkcheap SSR for the one above. I think that relay has something like a 7mA impedance, which should be fine to drive directly from an MCU.
    That relay above is still a SSR - just a much bigger one than the Dirkcheap one. To drive a real mechanical relay is a bit more complicated, and it shouldn't be needed for lights.
  6. Thanks ChristmasBuddy thanked for this post
  7. #6
    Aug 2012
    Forest, VA
    452
    Thanks for the response! How should the RJ45 be hooked up?
    Buddy
  8. #7
    Sep 2013
    Seattle, WA
    1,116
    You can match the DirkCheapSSR layout:
    orange/white to -
    any one of these to: +
    solid orange
    solid blue
    solid green
    solid brown
  9. Thanks ChristmasBuddy thanked for this post
  10. #8
    Aug 2012
    Forest, VA
    452
    Awesome!
    Mucho Thanks!
    Buddy
