Results 1 to 10 of 15
Thread: Dirkcheap SSR issues
    Aug 2012
    Forest, VA
    452
    Default Dirkcheap SSR issues
    Unfortunately, my FM transmitter is flat out not working so I have scrapped the show totally and just running the lights on with no sequencing.
    Everything looks good until day 2. Then two of my trees will not power off the lights. Even when my Ren32 is powered off and I know there is no data on the wire the lights stay on. I have to walk outside to the two trees and unplug the AC.
    On day 3, the lights do not come on at all. I go check the Dirkcheap SSRs and both of them are fried. I mean FRIED.
    While we have had rain my SSRs are protected inside of a sealed PVC pipe.
    The other thing that is blowing my mind here is that I am using other SSRs on bushes and trees. Knock on wood they are doing fine.
    Each of the light plugs on the two affected SSRs have only two strands of lights. I have 2-3 strands on the ones working fine.
    So my question is:
    Can Vixen be doing this? For these two affected trees I am using the "Set Level" under Basic Lighting. I have the Intensity set to 90%. These two trees are closet to the road so I only want them On.
    On my working bushes and trees I am using Twinkle.
    What really irritates me about this is that I did burn in tests for each of these SSRs for hours before I did my setup.
    Luckily, I have extra SSRs so I will continue to replace them as I need to until the season is over.
    Any ideas?
    Thanks!
    Buddy
    8,001
    Default Re: Dirkcheap SSR issues
    I'm gonna go out on a limb and say your attempt to seal them is doing more harm than good. You may have a good condensation cloud going on in there.
    I run mine in a PVC tube with a cap on one end and the other end completely open. The open end faces down of course. This allows moisture an easy way out.
    Vixen can't fry a controller. All it does is send control signals to the Renard controller. Then the Renard controller transforms this into low voltage pulses to control the SSRs. Even it couldn't fry an SSR. It has to be related to the AC mains power inside your tube making contact in the wrong way.
    --Jon Chuchla--
    Aug 2012
    Forest, VA
    452
    Thanks Jon,
    I mis-spoke. All of my SSRs are housed in a sealed PVC pipe but only on one end. It hangs from the sealed end. the other end is open for air circulation.
    The other difference with these two problem SSRs is that they are hanging up in trees and are not low to the ground like my others.
    This is just crazy. I'm thankful the others are not having issues. Knock on wood.
    Buddy
    8,001
    Birds? Bugs? Squirrels?
    --Jon Chuchla--
    Aug 2012
    Nova Scotia, Canada
    1,774
    Sounds like you may be running too much off each channel. The DirkCheap SSR's are only rated for 1amp/channel (Actually I heard it was more like .8amp/channel).
    I would measure what you are running from each channel to verify draw and ensure you are not pulling too much.
    5,348
    One other possibility is that moisture getting into the strings is creating sneak-paths for the current that is increasing the current draw for long enough to overload the SSRs chips.
    5,348
    --Jon Chuchla--
    or snails or slugs.
    Aug 2012
    Forest, VA
    452
    @DrNeutron
    I hear you but why am I not experiencing this issue with my other many SSRs in my
    yard? Its only for these two trees. I'll multi-meter the strands and get the results.
    @P.Short
    Possible I guess. I'll cover the female plug ends.
    Bugs?
    That's possible as these two trees do have their fair share of Stink Bugs. Under
    normal conditions I would smell them if they died in this manner and see whats
    left of their dead bodies.
    Buddy
    Aug 2012
    Forest, VA
    452
    Hmmmmmm
    After reading the comments here and researching more i am wondering if I am sucking up too many amps. I'll definitely do the multi-meter testing tonight.
    In the meantime, is there a good source for "high current" SSRs? I would like to get something quickly if that is possible (just as a safety measure in that direction).
    Thanks everyone!!!!!
    Buddy
    Morrisburg, On, Canada
    2,541
    Quote Originally Posted by UBotBuddy View Post
    ...In the meantime, is there a good source for "high current" SSRs? I would like to get something quickly if that is possible (just as a safety measure in that direction)....
    How "high" were you thinking of?
