Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Lights don't function like preview
    Williamsburg, VA
    917
    Default Lights don't function like preview
    Jon,
    In the video you can see the lights going down the driveway, the right side has the same effect (nutcracker-bars) just like the left but they are not functioning the same in reality. On the right the move back and forth but the left moves in one direction like the preview. I created a separate sequence with just this one effect and it is still the same way. I unpatched then repatched with same result. I had the effect on a group called outline then moved it to just the driveway but still same issue. Other effects like wipe function properly.
    here is the nutcracker settings.
    Winter Haven Florida
    3,039
    Default Re: Lights don't function like preview
    in the video it looks like they are running both directions but that would mean in the sequence you have it doubled up and 1 reversed can you take screen shot of that area of your sequnce
    James WinterHaven Fl
    7,872
    dumb question....have you tried restarting vixen. not the whole machine, just the vixen app. I've seen a handful of phantom effect problems lately, this could be one of those.
    Williamsburg, VA
    917
    There is a screenshot above just below the nutcracker settings. In a test sequence there was only this one effect.
    Williamsburg, VA
    917
    I have and I export to FPP.
    7,872
    Have you tried to set up this same effect with the current bars effect? (not the old one in the nutcracker effect)
    Williamsburg, VA
    917
    No but I will tonight after the show ends.
    1,048
    I noticed phantom stuff with preview enabled. I actually exported and it exported the preview on top of everything else.
    Williamsburg, VA
    917
    Same result, here is a video of an empty sequence with just the one effect bars on both sides of the driveway.
    I checked my E682 setup and this is the first output 1-1, the universe channels don't overlap.
    This is driving me crazy
    https://www.dropbox.com/s/v6m7o94q5f...17.07.mov?dl=0
    Maryville, Illinois
    1,668
    So explain the three items in the group? I see a line down each side of the driveway, but there are 3 elements in the group. Do DriveLt1, DriveLt2 and Drive Rt all have the same number of pixels in them?
