So a working 12V cane when plugged into a socket measuring 12V will not light the cane?
You are using a 12VAC transformer?
Is there a way you can measure the socket voltage with the cane plugged in and does it still measure 12V?
When you say "1 that won't light" is that only relating 1 channel?
If so, can you swap parts, like optoisolators, or are they soldered in?
It could be a bad connection, or a bad ic, or a bad triac, etc.
