Thread: SainSmart 8ch SSR board repair, need help.
    77
    Default SainSmart 8ch SSR board repair, need help.
    I have tested my setup tonight after setting it up and blew out my on my channels. I am running the 2a 8ch SSR boards from sainsmart powered by an arduino mega. In return this setup is powering C9 strings, one string per channel. I over looked one thing, the fuses in the strings are 5a, and the boards are rated at 2a, the strings only pull 1.47a, but I shorted out a bulb tonight. I am working on a way to fuse all my outputs (32ch) but for now, I need to repair the board. Here is an image of what popped, I am assuming that its a fused resistor of some sort but not sure.
    What is it so I can order and replace it. I have voltage to one side of it so I know the SSR is still operational.
    Thanks, and move the post if its in the wrong place.....
    Morrisburg, On, Canada
    2,540
    Default Re: SainSmart 8ch SSR board repair, need help.
    http://www.aliexpress.com/item/2A-fu...951913554.html
    http://ca.mouser.com/Circuit-Protect...a8hh?P=1z0x8gi
    Trick is to solder them in but not overheat them so they blow again with heat.
    77
    Thanks, I kept digging after posting last night. I found lower fuses to put in the individual strings and the barrel fuses on the board look like they are stamped 4A. For now I am going to use one of my extra channels and repair the board later. Thanks for the link.
    Sent from my LG-H900 using Tapatalk
    Mostly C9 Light Show, powered by Arduino. 48A Full On last year. "It feels like a carnival"
    https://www.facebook.com/ItsaDillonChristmas/
