Results 11 to 20 of 21
Thread: Mega Tree
    Galt, CA
    520
    Default Re: Mega Tree
    Quote Originally Posted by vziukas View Post
    At what height approximately you connect middle guy wires ? 5' ?
    I was a little above 5'. I used 3 guy wires at each level and a antenna clamp to go around the pipe. I was concerned about drilling any holes into the pipe that could weaken it.
    May 2008
    Allen, TX
    190
    Is anybody using pipe inside pipe ?
    [B]2009[/B] 88 channels (add SS24), 10.000 lights, 2 collor megatree, 12 mini trees, C9, floods
    [B]2008[/B] 64 channels (grinch+ren-c), 8.000 lights 12ft megatree
    [URL="http://www.christmasinallen.com"]http://www.ChristmasInAllen.com[/URL] for photo,video and how to DIYC
    Mooresville, NC
    7,590
    I use 4" PVC 10' long, then bought a reducer to 2" to get the 12'. I made a collar to slide inside the 4" and over the 2" to make it stable. Two sets of guy wires, and it is solid! I can post more pics if you like the concept.
    http://www.jamesfamilychristmas.com/...d=23&Itemid=36
    Ocoee, FL
    1,637
    Hey Wayne, looks great. Do you have any pics showing how you connected the guy wires at the top?
    Mooresville, NC
    7,590
    Quote Originally Posted by WWNF911 View Post
    I used a piece of .090 sheetmetal with a 2" hole dirlled in the center and three 3/8" holes 120* from each other. The corners were bent down to match the angle of the guy wires. It slides over the topper and then when the topper is fitted inside the 2" pvc, it is locked in place. The center guys are held in place with three brackets, (I think they were mirror hangers) and a hose clamp. I use the 12" lawn spikes (the GIANT nails) to secure it all to the ground with turnbuckels for easy adjustment.
    May 2008
    Allen, TX
    190
    Yes, please post more pictures. Good work. I check your page and like how you make controller. Very impressive !;)
    Mooresville, NC
    7,590
    Thanks.
    I did post a picture of the top pole with the reducer and collar in the post above. ;)
    Mooresville, NC
    7,590
    Here is another picture I just found buried up in another folder of the completed frame.
    (weird... the guy wires look funny in the picture)
    Cowes, Victoria, Australia
    603
    Look ok to me;) Another question tho, how do you hold the ring down? I see little post, then what?
    Kevin Lang
    64 Channel Olsen 595 64 Channel Grinch 4 Xmus Ren16's
    Running Acer P4 3.0 GHz and 1.00GB Ram Win XP
    Mooresville, NC
    7,590
    Quote Originally Posted by klanger View Post
    Ahhh, now that gave me some trouble....
    I made the posts first, I forget what size tubing it was, but I do remember is was "drinking water" tubing and fittings I used. It is a bit more expensive than regular PVC but the T's fit the electrical conduit perfectly for a snug fit. I cut the T's to make them slip fit over the conduit. I then drove 5/8" rod into the ground and slid the 'posts' over the rods. Once I got the ring level, I drilled through the bottom of the T through the 5/8 rod, then stuck a short piece of a metal coat hanger through the hole, like a cotter pin. This held the ring down to the ground height I set it at and makes for easy disassembly.
