Results 1 to 4 of 4
Thread: LED installation direction
    Tulsa, Ok
    428
    Default LED installation direction
    Bassboy had a problem with his FGDimmer system. We worked on it and we discovered that the SSR he was using needed the controller to sink the voltage to turn on the SSR. My personal SSRs need the controller to source the voltage to turn on the SSRs. He got his SSRs from a coop buy and they need the controller to sink the voltage.
    I can/will make a program to sink the voltage from the SSR but the module selection may need to be programmed into each 18F4525 I/C.
    Here is the importaint part: if you are installing the optional LED's, make sure you install them in the correct direction for your SSR's.
    spike Guest
    Default
    It is Sean's SSR's that will require the new program. Or any other 5v common instead of common ground system.
    Mar 2017
    3
    Default Re: LED installation direction
    Yup use 5v Power Supply
    Colorado Springs
    3,719
    You do realize that you posted to a 10 year old thread...........
