Xlights import
Can I make a request for a simple xlights import similar to how you have a LOR import?
I would find it easier to go from one program to the other if I could do a simple import back to HLS to sequence my dumb RGB and AC stuff while using Xlights to apply some effects to elements such as a matrix or MT while in xlights. Right now I am stuck exporting each model and then applying it to each PP.
Now that I think about this request as I write this......I would guess you would need a way to correlate a model to a PP to do a successful import.
Probably too complicated to look at this late in the year, but maybe mull it over for next?
Re: Xlights import
Man I am an idiot....
You wouldn't need to correlate anything, a simple import of channel info similar to a LOR import is what I meant to say.
Once the import is in, then you would create any PP's you want and then sequence.
I am getting scatter brained with the late night sequencing the past couple weeks.
- You may not post replies
- You may not edit your posts
Forum Rules
