Results 1 to 6 of 6
Thread: Error when oppening sequences
    Mechanicsville, VA
    1,072
    Default Error when oppening sequences
    I got this on one sequence then when I quit and tried to ope another it did the same. I haven't done anything yet because I don't want to comepletly lock things up. Do I need to uninstall and reinstall?
    "Index was out of range. Must be non-negative and less than the size of the collection.
    Parameter name: index"
    Ben
    128 lynx Freestyle DMX channels(not all used), 4 SSR4 DMX channels, 120 Ren24 channels, and 48 Ren16 channels!!
    Spencer Iowa
    1,236
    Default Re: Error when oppening sequences
    First make a copy of both your sequences and the profile you are using.
    Fist question. Are you using a profile?
    I am going to assume you are. Did you delete any channels out of the middle. Not at the end of the natural channel order.
    If you did it can be fixed.
    Joel
    Mechanicsville, VA
    1,072
    Quote Originally Posted by jrock64 View Post
    Joel
    Yes, thats what I did. I am saving a copy and just labeling them with a "2" on the end.
    Ben
    Spencer Iowa
    1,236
    Open a copy of the profile with notepad.
    Look for the <Outputs>0,1,2 ... </Outputs> section.
    I bet you see some -1s.
    Fix the errors or just renumber from 0 to your channel count -1.
    ie for 32 channels number from 0 to 31. No -1 and no duplicates allowed.
    This will reset your channel outputs back to the natural order but this can be easily fixed once you have salvaged the profile.
    The other gotcha is not to delete channels used by adjustable preview.
    If you do just add the channels back into the profile.
    Delete them from the preview.
    Then you can delete them from the profile.
    Wonder how I know these tricks.
    I do not part easily with two days of work setting up my July4 shows.
    Hope this helps.
    JOel
    Mechanicsville, VA
    1,072
    I didn't get it to work I actually didn't like the way the profile looked but couldn't redo it because I put 4 hours into it. I guess this helped me :p ;)
    Thanks though!!
    Ben
    Ontario, Canada
    2,147
    I encounterd this problem tonight,
    I added the channels back into my profile to recover from the crashes.
    However, I have not used the channels in question before or after the crash in the Preview, they appear there but they have nothing attached graphically.
    So How can you delet them from Preview? <-- stuck on this.
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
