Page 13 of 13 FirstFirst ... 3111213
Results 121 to 123 of 123
Thread: ESPixel GECE Info Thread
  1. #121
    Dec 2010
    Madison, Mississippi
    863
    Default Re: ESPixel GECE Info Thread
    Quote Originally Posted by PCPackrat View Post
    I loaded 3.0-rc3 last night after many attempts at not reading things thoroughly and finally got it. The web interface is really pretty. I will connect it to lights tonight and see how it works. There are definitely a lot more steps getting the flash all together.
    ANy special instructions and links to firmware version? I never could get 2.0 to load....
    2017 - Hmmmm...lots has changed...
    Facebook: Stevensfamilylightshow
    Youtube: Stevens Family Light Show
    Web: http://www.stevenslightshow.com (under construction)
  2. #122
    Nov 2015
    Covington, WA
    38
    Quote Originally Posted by duramadmax View Post
    The firmware is here: https://github.com/forkineye/ESPixelStick
    Read through the README.md dont skim like I did. There is a part (gulp) that requires java to 'zip' up the web site information. I just did that part in linux and then copied the files into the data/www folder in the ESPixelStick folder.
    Install the prerequisites in README.md
    Pay careful attention to the Arduino for ESP8288 version (2.40-rc1). You will have to choose this branch for download.
    My short and dirty TL;DR and things I missed:
    Modify ssid and passphrase at the top of ESPixelStick.ino
    Under Tools:
    Choose your board as Generic ESP8266 Module
    Flash Size should be 1M (128K SPIFFS)
    CPU Frequency 160 MHz
    Upload Speed 115200
    Power the unit with the button pressed
    Upload the firmware
    Remove power from the unit and replug again with the button pressed.
    Go to Tools and then ESP8266 Sketch data upload (serial monitor has to be closed for this)
  3. #123
    Nov 2015
    Covington, WA
    38
    I posted this under vixen but just in case, I'll do it here. I'm noticing a 400ms delay from when vixen tells the lights to do something and they respond. This makes sequencing to music impossible. I have faces using a renard and the espixel in serial mode and they are working great. Is this just expected behaviour with GECE? I have not seen anything about the delay in the forums and I dont remember it from last year. Only change from last year was the newer firmware and the newer version of Vixen. I downgrade vixen and the issue remained. I haven't tried loading 2.0 on a controller yet and see if that's it. Any other suggestions?
